Anyone having problems with the rear doors leaking? This was a problem I didn't know I had, primarily because the car was usually parked in the garage. Now that the car is back in the garage I still have a musty odor. The carpet is dry and no other moisture is seen or felt.
I first noticed the problem in the back driverside floor just behind the front seat. Then I noticed water puddling next to the rear seats just inside the door. Is it common for these door seals to leak? |
Mark,
Welcome to the forum. I'm on a lot of different PT forums and haven't heard of this problem your having. The rear doors have one long rubber molding around the door frame itself which comes together at the bottom. Have you checked the the whole length of the molding to see if it's seperated from the frame allowing water to come inside? One thing you can do it take someone with you to a Do-It-Yourself car wash and with one of you inside, the other person uses the high power wash against all the seams on the drivers side to see if you can spot where the water is entering.
hi mark and welcome to the board!! like crewzin said its got to be the rubber seal around the door good luck keep us posted on what you find out
The PT Sunroof has 4 drains, 2 front and 2 rear.
The rear drains are located outboard of the hatch hinges. Open the hatch and you will see a black rubber piece about an inch in diameter with a 1/4" hole in it. The front drains come down the "A" pillars on the inside and drain into the front cowl area where the wiper moter is and the HVAC air intake/Cabin Air filter area.
John & Terry ![]() "His" - 2002 Inferno Red Touring Edition "Hers" - 2003 Electric Blue Limited Edition Del Val PT Cruisers |
| Rear Hatch Opener Install ? | StevenAndEva | Sound and Security Forum | 1 | 24 Feb 2006 12:23 pm |
| Replace/install both sway bars or just rear? | im4gzs | Turbo Wheels/Suspension/Handling | 11 | 23 Feb 2004 09:11 am |
| Suicide Doors | SwtNLwPT | Exterior Accessories Forum | 6 | 22 Feb 2004 10:18 am |
| Rear door sill scuff pads | stronda | Interior Accessories Forum | 5 | 04 Sep 2003 05:46 pm |
| Rear anti-sway bar install on GT | JohnM | General PT Cruiser Discussions | 11 | 24 Jul 2003 07:38 pm |
