After timing belt change no more Air Conditoning?
Old 17 Mar 2006, 11:02 pm
Default After timing belt change no more Air Conditoning?
The AC unit is leaking freon last year but it still have some cold air left in the system but after they change the timing belt my AC is totally out of Cold air.....could they some how disconnected my AC system and all the freon leaked out or that my system is leaking bad.....I know for last two year all I have to do is fill it with one can and it would last for a yr but doesn't look like it this year.
Old 17 Mar 2006, 11:39 pm
Sounds like they may have drained the system somehow. Take it back and talk to them. Good Luck!!!
Changing the timing belt should NOT affect the A/C system.
Old 18 Mar 2006, 12:27 am
I believe the A/C system needs to be evacuated and disconnected to change out the power steering pump and then recharged. The power steering pump along with a lot more must be removed to do the timing belt.I think it's safe to assume the system may not have been recharged after assembly or a seal wasn't seated properly and leaked.
I would take it back to who did the job, they should stand behind their work.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 18 Mar 2006, 11:47 am
like said above im almost sure it has to be drained to change the belt , i would bring it back also good luck !! keep us posted
Old 20 Mar 2006, 06:23 pm
I'm jealous of anyone who needs AC this month.
Here in NY there is no shortage of Cold Air.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 28 Mar 2006, 01:24 am
Send a message via AIM to bigtommy83
First of all, thanks for polluting our environment and letting freon leak out of your car, knowingly.
Second of all, if your system was leaking, and they were able to tell, they probably lef tit empty, because it was leaking.
Or, the connector on the top/back of the compressor is broken off. I know when the motor gets raised up and down, it can sometimes grab on to the radiator fan shroud and break off if the motor is raised too high.
Check one of those two things. And fix your leak.
\'04 GT 5-speed, Brand X, Air Force One Intake, Custom Flowmaster Exhaust (retired), SRT-4 exhaust no resonators, AGP Wastegate, Crusher Kit, Former Chrome Package, Mopar BOV, Custom Sub Box, Mopar Pillar Gauges, Hood Scoop, MBC, Stage 1, Mopar Stage 1 Springs, Hurst STS
Future Plans: Custom Intercooler Sprayer, 2-tone Paint Job
\"Hondas are like cigarettes, everyone cool smokes them\"
Timing Belt Replacement Instructions PTFever Tech & Performance Forum 7 18 Jun 2011 01:23 pm
Platinum Plugs - Must change timing?? bnorth Tech & Performance Forum 8 21 Jul 2007 10:15 pm
when to change Timing belt ? Ctown General PT Cruiser Discussions 4 19 Jan 2006 10:39 pm
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
timing belt Thomas1 Tech & Performance Forum 17 03 Jun 2004 04:28 pm
