Spark plug change
Old 21 Mar 2006, 06:18 pm
Default Spark plug change
Hi everyone...new to this site...bought a PT 2001 LIMITED..very satisfied with only about 25,000 miles on it...and want to change the plugs on it...is ti something that is feasable or do we have to got the mechanics ?
tx
Old 21 Mar 2006, 06:44 pm
Dan,
It sure is possible for the novice to change the plugs on the PT. The wires are a weak point in the ignition system also, so you would want to change them while the upper manifold is off. Use Dielectric grease on the plugs wires and anti-seize on the plugs. For a 2001 the hardest part is getting the EGR pipe off the back of the manifold. There's two different size (10mm & 13mm I think) bolts that have to come off before you can move the upper manifold out of the way. See if you can get into this Imagestation link and it will give you step by step directions.
http://www.imagestation.com/album/?id=4291473219
OH yea, WELCOME to the forum.
Old 22 Mar 2006, 10:24 am
PRCruzr's write-up (and picks) are great.
DON'T just change the plugs - DO THE WIRES also. The stock wires are crap. I suggest Crane wires (RaceAndStreet.Com) - you'll get them in a few days...They'll last much longer than the stock ones.
an '01 with 25,000 miles??? I have nearly 19,000 on my '05!
Old 22 Mar 2006, 02:27 pm
wow! this is neat ! thanks alot....It can not be easier then that.....unless yo pat for it ! [?]
yeap only 25,000 miles...overs here it 54,000km..and very very clean...
Old 22 Mar 2006, 05:52 pm
welcome to the board !![8)]
Old 22 Mar 2006, 06:22 pm
thank you ! it's a pleasure you seem to ba working in the same environnment as I am ? Verizon...Bell..
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
2006 non turbo spark plug change samson77 Tech & Performance Forum 9 06 Feb 2007 12:36 am
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
new spark plug wires gottago Tech & Performance Forum 22 30 Oct 2004 02:26 pm
spark plug change Joe General PT Cruiser Discussions 9 29 Oct 2003 12:21 am
