Suspension problems
Old 27 Mar 2006, 05:57 pm
Default Suspension problems
I had some clunking noise in the rear of my wife's 02 Touring Edition cruiser, so I took it to the dealer today. It has 44,234 miles on it. They said the rear sway bar had to be replaced at a cost of $154.95 including labor. I told them to go ahead, when it was finished, they said there was also a clunking noise in the front end. I had never noticed it, but I seldom drive the car. They asked if I would like them to investigate it and I said sure. It turns out that the front lower control arm bushings on both sides are worn and need replacing. I asked them if this was normal, they said "it happens". My question to the forum is, has it ever happenned to any of you? They want $455.00 to replace them. Thanks for your comments.
Manny
Old 27 Mar 2006, 06:56 pm
hi, welcome to the board, does it happen yes , i have an 03 turbo just turned 10,000 miles had to have both changed they told me that they were bad from the factory!! my car was still inder warrenty so it cost nothing, i dont think there was a recall on them but call chrysler direct and ask them good luck & keep us posted
Old 28 Mar 2006, 09:45 am
Welcome, Manny.
I also lost my rear sway bar on my '02 - hit a bad pothole somewhere around 80,000 miles. I had them check all suspension bushings, and all else was okay.
It's a variable thing - my son's car (not a PT) needed them at 60,000 miles.
Old 28 Mar 2006, 12:56 pm
The lower control arm bushings are bad in mine also
I have owned a lot of vehicles over the years and this is the first time I have ever had this type of problem[xx(]
There should be a recall on them, a cheap part that should never have been used!
Old 28 Mar 2006, 03:11 pm
In our 2002, they were replaced at 17-18K miles, they started to seperate and were replaced under warranty. 38K on it now and no problems with the replacements.
Our 2003 has 23K miles and the originals are doing fine.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 30 Mar 2006, 04:45 am
I dont like the stock busing that the dealer installs in the lower a arms. Not enough flex especially if you have air suspension or you have lowered your PT. I would recommend you use the polyurethane bushing by energy suspension. You can buy them from autotrucktoys.com for 49.95 plus shipping. They will last many times over what the stock rubber ones that deteriorate very fast. Hope this help out. Later[^]
Pete
Old 30 Mar 2006, 05:48 pm
My 2001 lmtd just started clanking in the rear...
sounds like something coming thru whole rear deck..
can the bushings only be replaced or does the whole
bar/bushing need be??? black][/black]
texasrigmike
Old 30 Mar 2006, 08:57 pm
On mine they told me that the whole sway bar had to be replaced, cost me $159.00 with labor.
Old 31 Mar 2006, 05:00 pm
Anybody have a P/N and online source for this sway bar/link?
Old 28 Apr 2007, 08:54 pm
infernocruisr01's Avatar
Send a message via AIM to infernocruisr01
Default Re: Suspension problems
does the energy suspension bushings sqweak during the winter months.. i'm just curious cause i'm from new hampshire????
So much problems before inspection Ctown General PT Cruiser Discussions 3 12 Apr 2005 07:45 pm
GT Suspension Better? 340x Turbo Wheels/Suspension/Handling 9 03 Jan 2005 02:03 pm
Anyone running the MP suspension? sca037 Wheels, Tires, Suspension 5 17 Jun 2004 01:41 pm
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
Autocrossing with air suspension renichms Tech & Performance Forum 2 12 Apr 2002 10:29 am
