PT Cruiser Forum Car Videos
Custom Wheels
trac control & abs light staying on in dash
Old 04 Apr 2006, 05:36 pm
bobs turbo pt bobs turbo pt is offline
Default trac control & abs light staying on in dash
hello all, was on the way home from work and i got a chime i looked at the dash and the trac control and abs light are lit on dash board, i got home shut car of re started it and they are still lit nay thoughts ??[:I]
Old 04 Apr 2006, 11:01 pm
Hooligan Hooligan is online now
Try disconnecting your battery for about 5 minutes, may reset the computer. Try that first.
Old 05 Apr 2006, 09:04 am
Agree w/Hooligan. If it comes on again, you may have a brake caliper hung up, not releasing.
Old 05 Apr 2006, 10:28 am
purple04 purple04 is offline
The most common problem on ABS systems is one of the wheel sensors or circuits. Haven't seen a pattern failure for PTs, but getting the code pulled should point you in the right direction.
Old 05 Apr 2006, 11:52 am
fritz_t_coyote fritz_t_coyote is offline
Yeah, one thought:
Pull the codes... and look them up.
and either fix it yourself or or drive carefully to a good shop and get it fixed as soon as possible.
The light is telling you that ABS and Trac Control are not working, and may be just the tip of an iceberg of brake problems. Or just a sensor connector came loose. Either way, PLEASE take care of it soon, we don't want to see pictures of your turbo wrapped around a flagpole.
www.visualizecommonsense.com
Old 05 Apr 2006, 05:31 pm
hello all, started the car this morning and no trac control and abs light on dash all seems ok going to check for a code
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
Trac control, wiper switches on center dash Espresso General PT Cruiser Discussions 6 04 Apr 2005 09:50 pm
obd-II codes Punch General Turbo Discussions 5 06 Nov 2003 02:34 pm
  0 Credit Cards | Personal Injury Attorney Los Angeles | Free Credit Reports | Loans | Loans
