Any of you guys got this problem? When the rear go over bumper surface it emit this knocking noise near the wheel well. It seems come from either side......it sounds like this Klock Klock Klock!
I have someone took everything off and still the problem is there. Even the bumper is replace and shock and everything bushing sway bar or either replaced or taken off for inspection and still the sound is there. I wasted whole lot of $ on this car and I still can someone fix this problem or atleast find it. The sound is from somewhere behind the rear sits Got any idea....I'm almost at a point that I may need to find another car. |
Do you have an aftermarket exhaust? Some of us had knocking from an aftermarket exhaust from the the part of the exhaust pipe that went over the rear axle. When you it a bump, the rear axle went up and hit the pipe.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 100,000 miles, Original Owner Visit My Home Page www.CREWZIN.com |
crewzin has a good point, i also had a knock in the rear of the car drove me NUTS !! i had my wife sit in the back to listen , the sound was from the rear of the car but it was the styrofoam that is above the headliner !! they ( dealership) reglued it and all was fine just a thought, like i said i was under this car for days going crazy !! good luck keep us posted
after market exhaust hitting axle.
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
bad bushing in the bellcrank, part of the Watts Linkage which laterally stabilizes the rear axle. as soon as you mention it to the parts guy - he'll know exactly what you mean. its a common part failure. costs about $150 for the garage to change...
i just fixed it in my 01, as i was chasing this problem for awhile... |
I'm thinking Watts link also.
John & Terry ![]() "His" - 2002 Inferno Red Touring Edition "Hers" - 2003 Electric Blue Limited Edition Del Val PT Cruisers |
Now that you mention it, the gas filler tube on our 2002 was an issue, sometimes bumping against the black hold down bracket used for shipping the PT. I used a long Zip Tie and secured the tube to the bracket using the hole in the bracket and wrapping the Zip Tie around the tube.
Another issue we had with the 2002 is the right (Passenger side) end of the rear sway bar coming loose from normal use. The bolt at the end of the bar that attaches it to the link would come loose just from the boby moving up and down. The factory calls for the bolt to be torqued to 40 or 45 foot pounds but would still come loose. I tightened it to 50 foot pounds over a year ago and no problems. Note, when this would come loose, I didn't get a knock or thump but usually a squeak.
hey ctown, it is above the headliner believe me i thought the noise was coming from back passenger side wheel wheel then i had my wife in the back seat all i had to do was drive around the block and my wife said its coming from "up here" she pushed up on it no more noise i brought the car in and they fixed it, im not saying this is your problem its just a thought
If Ctown could tell us if he has any suspension mods it would be helpful
| Car over Heated white smoke knocking noise dying | Ctown | General PT Cruiser Discussions | 26 | 28 Apr 2009 06:03 pm |
| mysterious rear knocking noise was found FIXED!!:) | Ctown | General PT Cruiser Discussions | 3 | 01 May 2006 12:40 pm |
| update on that mysterious rear knocking noise | Ctown | General PT Cruiser Discussions | 6 | 25 Apr 2006 09:55 am |
| Knocking noise from rear end | Ctown | General PT Cruiser Discussions | 9 | 22 Nov 2005 06:08 pm |
| Road noise / exhaust noise in the car. | jackatg450 | Tech & Performance Forum | 3 | 21 Jul 2004 10:55 pm |
