PT Cruiser Forum Car Videos
Custom Wheels
update on that mysterious rear knocking noise
Old 21 Apr 2006, 05:58 pm
Ctown Ctown is offline
Default update on that mysterious rear knocking noise
I had to check it myself so heres the update.
1)not the spare tire bracket or screw. I totally took that assembly out.
2)not the gas tube since I secure it already
3)not head liner or whatever
4)NOTHING I can find is bumping into other part or even loose
5)even the bellcrank looks OK the bushing looks OK but thristed just a little I can't seem to really tell if it went bad. I also pulled on it pretty hard and it only move slightly
6) the whole wattlink seem OK unless it's a busted ball joint but if thats the case I can move it around when I pull it.
I still suspect the ballcrank is damage internally or one of those arms with balljoint is F.
I don't know and I'm VERY VERY upset at this car right now.
Old 22 Apr 2006, 05:34 pm
bobs turbo pt bobs turbo pt is offline
man o man its gotta be driving you nuts at this point !![xx(]
Old 23 Apr 2006, 11:43 pm
Sandy-GRR8PT Sandy-GRR8PT is offline
Does anyone else hear it ???? Not to say you imagine it.. Just that maybe someone sitting in the back seat can find it..Just a thought..
Current Mods: Removing small pieces of paint on the hood and grille by painstakingly driving into flying debris kicked up by preceeding vehicles
Old 24 Apr 2006, 12:56 pm
Jimbo Jimbo is offline
You never did say if you have a after market exhaust.
When does this knock happen??
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 24 Apr 2006, 03:20 pm
You have a rear sway bar?
Be sure all links on it are tight.[:I]
Old 24 Apr 2006, 09:54 pm
I don't have an after mark exhaust. This knocking happen like few weeks after the new sway bar and bushing. I have tighten everything. It's a LOUD noise too and the Mech and his guys have try eveything....
I may goto a different shop but it'll have the same result.....this IS driving me nuts alrite
Old 25 Apr 2006, 09:55 am
Zero in on the sway bar. I put in a rear and got a clunk & also erratic handling at times - I got under again and tightened everything up, and problem disappeared. All bolts have to be TIGHT!
Particularly the clamp that holds bar to axle - apparently on mine, being loose allowed it to move side-to side.
vB code is On
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
mysterious rear knocking noise was found FIXED!!:) Ctown General PT Cruiser Discussions 3 01 May 2006 12:40 pm
Still can't find the knocking noise at rear!HELP! Ctown General PT Cruiser Discussions 12 21 Apr 2006 03:20 am
Knocking noise from rear end Ctown General PT Cruiser Discussions 9 22 Nov 2005 06:08 pm
Roaring noise from the rear when reversing?(FIXED) Ctown General PT Cruiser Discussions 3 17 Apr 2005 02:51 pm
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  Mobile Phones | Myspace Layouts | Homeowner Loans | Internet Advertising | Free vBulletin Skins
