Need some advice
Old 25 Apr 2006, 07:02 pm
Default Need some advice
Purchased a polished stainless steel piece to put under my hood. It is the large section. My question is, do those of you who have this mod leave it on all the time or do you use it just for shows. I want to install it, but I am not sure I want to have to put it on and take it off on a regular basis either. All help is appreciated.
Old 25 Apr 2006, 07:07 pm
I have a piece of mirrored Mylar that I ony use for car shows. It is held on by velcro that is for commercial use. IF you go that route make sure that the "loop" side is mounted on the car, otherwise when you detail your car the threads on the wiping rag will catch on the "hooks"[xx(]!!
Old 25 Apr 2006, 07:20 pm
I've had my liner on for about 2 years, and it doesn't seem to cause any problems. It is pretty easy to clean with window cleaner, and doesn't get all that dirty to begin with. The only thing I have trouble with are the screws vibrating out, try using loctite on the screws when you install the panel. Also, if you have a strut bar, check for clearance, mine has a couple of rub marks on it from the strut bar.
Old 26 Apr 2006, 07:24 am
Thanks for the information. I think I am going to install it and leave it there. I do keep pretty good care of the Cruiser and try to keep it clean outside as well as under the hood.
Thanks again for your help guys.
Old 26 Apr 2006, 09:15 pm
One other thing the "blanket" under the hood is supposed to drop down over the engine in case of a engine fire. Without that little bit of protection, you could have a problem with your insurance company.
Need some advice !!!! blarneyny PT Cruiser Convertible Forum 0 31 Jul 2005 03:31 am
Advice on Bridgestone Potenza tires, please stargazer Turbo Wheels/Suspension/Handling 20 29 Oct 2004 01:46 am
My PT must sleep in the open, need advice on care Edwin Astacio The Detail Shop 8 28 Oct 2004 08:37 am
Please help...I need some advice. Rainman General Turbo Discussions 14 10 Aug 2004 11:10 am
Advice On Selling... Cruizin2k General PT Cruiser Discussions 12 02 Jun 2004 01:07 pm
  Wordpress Theme | Myspace Images | WoW Gold | Debt Consolidation | Wordpress Themes
