Headlight Problem
  #11 (permalink)
Old 15 Jun 2006, 12:58 pm
dag dag is offline
Sure its not the bulbs? Sometimes its hard to tell if they are burned out.
  #12 (permalink)
Old 20 Jun 2006, 04:50 pm
dag dag is offline
Well what was the fix? I love it when someone jumps on here and asks a question, gets a bunch of ideas and then never repsonds so that everyone else might learn something
  #13 (permalink)
Old 20 Jun 2006, 05:21 pm
hey jmack did you get the problem solved ??[:I]
  #14 (permalink)
Old 21 Jun 2006, 03:41 am
thegoldpt's Avatar
Send a message via MSN to thegoldpt Send a message via Yahoo to thegoldpt
If i recall right, there are 2 bulbs, one for low beams and one for highs, when in low beams, only one comes on, but when on high beams both come on. Do both bulbs come on when you turn it on? Or just high bulbs come on.
  #15 (permalink)
Old 21 Jun 2006, 09:51 pm
Send a message via AIM to jmack
ok, well as up to now, I have no solution. The dealer cannot figure it out. I am going to take it to another dealer and see what i can find out....I promise I will post once i figure it out.
About to start work on modding my car and making it look even better than it already is!
  #16 (permalink)
Old 22 Jun 2006, 12:55 pm
dag dag is offline
Thanks for the update.
You must have some sort of grounding problem or something thats hard to track down.
Good luck with the second dealership
  #17 (permalink)
Old 24 Jun 2006, 01:29 pm
good luck and keep us posted !!
  #18 (permalink)
Old 26 Jun 2006, 02:40 pm
If fuse is good, bulbs are good, and you've replaced the switch, then it has to be wiring. Must be near the switch where wire's common, or else 1 side would work. [:I]
  #19 (permalink)
Old 18 Jul 2006, 12:01 am
Ok guys, I finally got this mess fixed. Found out what was causing it was the wiring harness. It was just fried. It looks like it has shorted/got hot and melted some of the plastic...and then it got brittle and the wires were not making a connection. How did I solve this? I contacted the dealer and needless to say my solution was a lot easier. they wanted to charge over 250 dollars including labor to replace this. I took a quarter, wrapped it in electrical tape,and put it in between the two pieces of plastic. This made the harness tight again and the contacts worked again. Needless to say, my repair cost 25 cents instead of 250.00. Now the airbag light is coming on. My Scion tC is on its way, so can't wait to trade this stupid car.
  #20 (permalink)
Old 18 Jul 2006, 09:03 am
Good show!
Hey, who was it who said it must be wiring?
You were fairly lucky, those harnesses are nasty to find individual wires in!
Hey, what state quarter did you use? [)]
ARRG!! Odd problem and loose sensor Jason_L General Turbo Discussions 4 18 Mar 2006 01:40 pm
stage 1 install problem gooberff Stage Turbo Kits 6 29 Jun 2005 12:22 am
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
Sqealing problem in 2003 PT Cruiser labradorlover Tech & Performance Forum 21 31 Dec 2003 03:44 pm
