hey guys,
The other day, my low-beams wouldn't work. Only the Hi-Beams. I had to drive home with them on which was not much fun. I figured it was the Multifunction Switch. I ordered a new one, put it in, and Guess what...Didn't work...Am I missing something guys? |
Something as simple as the bulbs being burned out??
let us know what you find out
Ok, well it can't be the fuse because the Hi beams work. There isnt a fuse for low and hi (or is there?)
The bulbs are fine, I checked them and they haven't blown out. Any other suggestions?
About to start work on modding my car and making it look even better than it already is! |
I have a suggestion. First is the car still under warranty? If so take it to the dealer and have them look at it. I believe the possible cause is the multi-function switch that controls high beams low beams and fogs and turn signals...that may more than likely be the prob. i had a similar problem but mine got stuck on high beams so it was high beams or fog lights for me...but this to sounds like the switch is bad. Brian
03 gt painted steel blue, goldline coil springs custom exhaust done by yours truly..k&n typhoon intake..tinted windows member of ptcruiserclub.org..adjusted wasetgate. E&G classic billet grille. 600w alpine amp,2-twelve alpine typeR subs,alpine headunit.xeon headlights,fog lights.apc carbon fiber taillights. royal purple oil. k&n oil filter,mopar bov conversion,BTG strut tower brace.... |
He said he already replace the switch;
Check out the bulbs, if you're getting power to the sockets, fuses, etc. Start out small first (assuming you didn't).
Here is picture of My Cruiser\'s Mirror
The bulbs are fine, because when the hi beams are on. they work...so it isnt the bulbs...I have already replaced the switch/checked fuses..
On my 2001, the fuse panal by your left knee. I have two (2) 10A fuses for the headlamps, Nr's #19 & #20. Do your have the same? Did you check them both? [:I]
| ARRG!! Odd problem and loose sensor | Jason_L | General Turbo Discussions | 4 | 18 Mar 2006 01:40 pm |
| stage 1 install problem | gooberff | Stage Turbo Kits | 6 | 29 Jun 2005 12:22 am |
| I think I'm having a power steering problem! | lumofny | Tech & Performance Forum | 5 | 18 Jan 2005 01:12 pm |
| Unknown RPM surge problem (manual) | Ctown | Tech & Performance Forum | 4 | 26 Dec 2004 08:48 pm |
| Sqealing problem in 2003 PT Cruiser | labradorlover | Tech & Performance Forum | 21 | 31 Dec 2003 03:44 pm |
