PT Cruiser Forum Car Videos
Custom Wheels
Early front pad wear 06
Old 03 Jul 2006, 04:02 pm
Kzac Kzac is offline
Default Early front pad wear 06
I am experiencing early pad and rotor failure on my 06. At 15.5k I am showing wear on the rotors and pads. Has anyone tried aftermarket rotors and ceramic pads to cure this issue?
Thanks
Kzac
Update, When I removed the front pads, they were about 1/2 worn the rotors were almost at the maximum limit of wear 21.9 mm vs 21.4 mm max wear.
The problem is in the excessive dust the brake pads produce. The dust clogs up the area where the pads actually slide, this causes a situation where the pads can not relax after breaking because of the accmulation of dust in the sliding area.
Changing the pads and rotors has greatly reduced the dust and my fuel mileage has improved about 4-5 mpg. I plan on trying ceramic pads later
Kzac
Old 03 Jul 2006, 10:23 pm
Hooligan Hooligan is online now
I put ceramic pads on my 02 to elimanate dust, it did and I was pleased. Haven't heard anything about excessive wear on the 06 in particular.
Old 03 Jul 2006, 11:46 pm
bobs turbo pt bobs turbo pt is offline
i would go back to the dealership and ask them to check it out
Old 04 Jul 2006, 03:43 am
bigslim bigslim is offline
I'm going on 10,000 miles and mine are grinding bad.
2006 PT Cruiser (NEW)
17X7 Motegi Wheels
215/45-17 Hankook Tire
Front lowered 1.5 inches, rear lowered 2.5 inches
Kenwood in dash CD/Sirius/Six Disk Changer
First of a few mods
2004 Mercury Marauder (Supercharged)
http://www.cardomain.com/id/bigslim2
http://www.cardomain.com/memberpage/484421
Old 05 Jul 2006, 11:06 am
tpscruiser tpscruiser is offline
I have heard of folks who do 90% city driving, needing pads at 12K.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 07 Jul 2006, 09:27 am
Same here. The ceramics also felt better and lasted longer. Put them in my daughter's '03 GT, and I'll be putting them in my '05 soon.
I got Raybestos ceramics.
Old 08 Jul 2006, 02:34 am
SteelBlueGT SteelBlueGT is offline
I used and highly advise using the Raybestos (PepBoys) ceramic pads up front. No dusting and longer wear and slightly better fad and stopping power. I also went with slotted and drilled disks and SS lines all around. Biggest improvement was the front pads. I already have about 20,000 miles on the front pads and they are hardly (20%) worn according to my lube man. Got my rotors on eBay and they were cheaper than a stock replacement. I did not need new rotors at 30,000 but I wanted the upgraded ones anyway!! [?]
vB code is On
Front license plate placement spicy pt Exterior & Interior Styling 50 16 Oct 2008 08:52 pm
Please help, front end shimmy survey Boomer Tech & Performance Forum 11 28 Mar 2005 01:33 pm
Sway bar size front and rear AlmondTurbo Turbo Wheels/Suspension/Handling 0 28 Jun 2004 02:15 pm
camber alignment kit needed for front ??? boosta Turbo Wheels/Suspension/Handling 7 10 Jun 2004 11:25 am
Mirage Hot Rod Grille(s) and Front Fascia SurfinUSA Classifieds: For Sale/Trade 10 10 May 2004 12:23 am
  Power Rangers | Loans | MySpace Layouts | Mortgage | Loans
