Evry thing went fine for a few weeks with the new engine but today I find out that the heater hose is leaking cause the bottom of the hose is wet with coolant
what the hell?! I just tighter the clamps a little bit and hoping for the best |
keep an eye on your coolant level also
The coolant level drops an inch a day in the reservior. I can't tell where the coolant is leaking but the buttom hose is wet. and if I touch the hose the coolant drop faster.
Man I still have to wait until thursday for the fix! |
i would bring it back to the shop were they replaced the motor and tell the guy about it!!
Be sure u are correct about the hose leaking. The heater core is a plastic nippled piece of crap very weak in design. Never pull on the heater hose to dislodge from core instead carefully slit hose with razor blade to seperate from core. place a piece of cardboard under car try to pinpoint leak .Behind crossmember about where gas pedal is is a drain hole where if your core is leaking it will drip out of.
did you get it fixed yet ??
glad its fixed!!
| Check Engine Light came on - code 1188? | coolvirus | General Turbo Discussions | 18 | 09 Jan 2008 01:14 pm |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Error Codes | skylight | Tech & Performance Forum | 6 | 07 Apr 2007 02:19 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| Leaking coolant line | TripleJackInGA | General Turbo Discussions | 0 | 03 Oct 2003 10:00 pm |
