cruise control dropping
Old 15 Aug 2006, 01:14 pm
Default cruise control dropping
Has anyone had a problem with the cruise control dropping out? Mine will engage and then after a few minutes drop out- I can re-engage it but it will drop out quicker each time I try. Then the dash light "cruise" indicator will not light up. If I shut the engine off at a stop, the whole process repeats. Then occasionally it will work ok. Help!
Old 15 Aug 2006, 05:16 pm
you should check to see if you are getting any codes ??
Old 15 Aug 2006, 07:59 pm
Check the vacuum line you may have a leak. The cruise control module in on the passenger side obove the strut tower.
RETROPT - 2001 PT Sedan Delivery
Old 15 Aug 2006, 08:20 pm
Had cruise control added to my wife's new car (not a PT and didn't come with CC) and after about 2 months it started to do the exact same thing. I thought it might have been some sort of vacuum leak but when I took it back to the place that installed it, they said it was a bad solinoid. Only took about 20 minutes to fix it.
Old 15 Aug 2006, 10:05 pm
Do they still use vacuum on the cruise control? I thought that it is all electronic now....
Old 17 Aug 2006, 07:03 pm
All electronic on models with throttle-by-wire (not PTs). Others use the PCM to actuate solenoids that open/close vacuum ports on a vacuum motor (PTs).
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
Cruise Control Glitch gtbright General Turbo Discussions 0 12 Feb 2005 08:36 pm
