PT Cruiser Forum Car Videos
Custom Wheels
ERROR CODES
Old 21 Oct 2006, 05:49 pm
Kirby Kirby is offline
Default ERROR CODES
Anyone had to deal with error code P0129 - barometric pressure too low?
Help!
Old 22 Oct 2006, 07:38 am
CREWZIN CREWZIN is offline
I think that means you better head for cover because a hurricane's on the way!
Sorry, Florida humor. [:I] Not sure what it means with the PT. Hopefuly someone will come along and know the right answer.
2000 PT. 95K miles, Original Owner
Old 22 Oct 2006, 10:12 am
deederz deederz is offline
[:I]Odd, My list of error codes goes from p0128 (Thermostat related) to p0130 (o2 sensor related) I'll keep lookin. found some more 0129 is bad sensor for barometric pressure.
Old 23 Oct 2006, 12:09 pm
P0129 Barometric Pressure Out of Range - Low (Turbo only)
[:I]
Either sensor is bad, or you have a leaky hose/clamp somewhere.
Old 24 Oct 2006, 03:15 am
strangelove strangelove is offline
If it's a bad hose you might be able to locate it by listening to the engine while it's running, if you can hear a noise of an air leak and locate the hose that's bad you could do a quick fix by wraping it with duct tape. Them order a replacement hose. Heard about a similar problem on that car guy's radio program on NPR.
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
vB code is On
  Cell Phones | Debt Help | Apply for Credit Card | Web Games | Web Advertising
