PT Cruiser Forum Car Videos
Custom Wheels
REMOVING DUALS?
Old 09 Nov 2006, 10:20 pm
mjb457 mjb457 is offline
Default REMOVING DUALS?
Has anyone removed thee duals & reinstalled factory exhaust. What did you do with the cut out? Any other additional problems thanks ,,,[8)] MJB
Old 10 Nov 2006, 11:30 pm
1wedwudy 1wedwudy is offline
Guess you could install one of these fake exhaust pipes in the cutout. Moss Motors sells them. www.cruiserbits.com
Old 11 Nov 2006, 02:08 am
strangelove strangelove is offline
Or you could use a fiberglass repair kit and repaint the bumper. Why are you removing the duals?
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
Old 11 Nov 2006, 12:04 pm
bobs turbo pt bobs turbo pt is offline
thats a great idea redhot !!
Old 11 Nov 2006, 09:01 pm
[8)]I like the look and performance of my Borla duals.. Ive even added a resonator,,they have been on for almost 4years... i just dont like the added noise on the highway when cruising.. any ideas? thanks MJB[8]
Old 13 Nov 2006, 06:29 am
Another thing you could try is installing acoustical insulation in the back of your PT, the kind you can get at a good car audio shop. If you still feel like parting with your duals I might be interested in buying them from you.
Old 13 Nov 2006, 09:14 am
[8]Hi I like the insulation idea... how much & where do I install it?Thanks,,,,,,,,[8)]MJB
Old 15 Nov 2006, 05:29 pm
keep us poted on what you do !![^]
Old 15 Nov 2006, 08:39 pm
[8]Ok I just added more carpet padding in the cargo are & additional Thicker mats & also blocked the open seat area between the rear spli seats & notice a difference! I think if I can find something to insulate the back area totally it would be fine! It right now is actually ok..... thanks for the suggestions & anymore would be truely appreciated![^]
Old 16 Nov 2006, 08:19 am
Mjb glad the suggestion worked for you, you can get acoustic insulation at any car audio shop or you can order it off the net from Crutchfield or someone. Here's a link: http://www.crutchfield.com/S-mwSqkN7...890&I=15411105
It's really thin stuff and you can line your whole car with the stuff, line the floors under the carpet, under the side panels, roof, line your hood, firewall, etc. It will also insulate and keep the car warmer during winter. I used similar stuff like this when I built a teardrop trailer and it worked really great. If you want to go the whole nine yards to insulate noise and the cold, use liquid expanding foam in the corners or hard to reach spots. Just know with foam that if there are wires or moving parts behind the panels it might get in the way of them. Do all that and you'll be running the quietest PT around, close the doors and you won't hear a thing from the outside.
vB code is On
REMOVING DUALS??? mjb457 General PT Cruiser Discussions 5 01 May 2006 01:55 pm
BTG Duals quicksilverdon General PT Cruiser Discussions 6 18 Apr 2005 09:40 pm
removing silicon from paint gonzomania The Detail Shop 1 28 Jul 2004 10:08 pm
Removing Oversprayed Clearcoat TripleJackInGA The Detail Shop 6 06 May 2004 07:16 pm
Removing Swirls turbomangt The Detail Shop 3 26 Feb 2004 02:52 pm
  Loan | Loans | Debt Help | Debt Help | MPAA
