High seat position
Old 12 Feb 2007, 01:50 am
Default High seat position
Does anyone else have a problem with the PTs front seats being too high? Is they a kit or something out there to lower them about 3 inches? Thanks Larry
Old 12 Feb 2007, 08:35 am
Larry,
Do you have the drivers side power seat? The only thing the power does is raise and lower the seat. No forward/back movement, that's still done manually. If you don't have the power seat, I'm not sure of the height that the non-power seat is at, but it might be too high for you. Try siting is someone's PT that has the power seat and lower it all the way to see if that meets your needs. If it does, of course, you'd have to spend the $$ to buy a new power seat or find one in a recycle yard.
Old 12 Feb 2007, 11:16 am
Welcome, Larry.
I agree with you. The power seat doesn't go down low enough, and a sunroof makes the problem worse.
there have been threads about this since the PT was new, but I never saw anyone that did anything to solve it, other than recline the seat a bit.
What I did think about was to take the seat out, cut the sides of the base, overlap the cut sides and either bolt or weld them together.
Old 14 Feb 2007, 03:58 am
I got the power seat and I think it even in its lowest position is too high but I set my seat recliner back just a bit and I find the sweet spot. Also, my power seat does go in 6 directions - forward and backwards - up & down - and angle front and rear. But you have to have the recline back to about 80 degrees for angle back. I do wish the seat went back more...at least its comfortable.
Rear Seatbelt locked with seat folded flat WonderMur General PT Cruiser Discussions 9 03 Nov 2013 11:00 pm
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
