Is your traction control off when you turn car on?
Old 23 Feb 2007, 04:58 am
Default Is your traction control off when you turn car on?
hey all, when I turn my car on, the traction control is automatically off. Is this normal? I know is most cars default with it on. Its not really a problem, I'm just curious... cause I'd imagine this could mean that the computer has been messed with by the last owner.
Old 23 Feb 2007, 09:26 am
The TRAC light should come on, then go off - similar to air bag.
Even if you shut TRAC off withthe switch, next time you start the car, it's on.
Old 23 Feb 2007, 11:11 am
always on here
Old 23 Feb 2007, 02:20 pm
maybe the last owner got this thing tuned??
it still only holds 11 PSI at best though (spikes to 15)... which from what I hear is stock.
Old 27 Feb 2007, 01:04 pm
This is the same GT with a Glass-Pack instead of a Cat, and O2 sims fooling the computer?
Are you sure the ABS works?
Can you turn ON traction control by hitting the switch?
Full Throttle in First Gear from a dead stop should be enough to make Traction Control engage.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 27 Feb 2007, 02:37 pm
ABS works, traction control works. It was snowing the other day so I know this for sure. I've noticed its on and off randomly when I start the car. Its a roll of the dice. sometimes its on, sometimes its off... and yes I can turn it on and off manually by hitting the switch.
Old 28 Feb 2007, 12:49 pm
sounds like a sensor acting up as one of mine is now after driving in the snow sunday night !! trac control on & off on & off [xx(]
Old 01 Mar 2007, 03:43 am
if the green TRAC light was comming off by the odometer I'd suspect that too... but I'm talking about the yellow TRAC OFF light on the temp/fuel pod. The last 5 times I've started the car now the trac has been on.. so I don't know what the deal is. Maybe the computer has fuzzy logic or something... I know the old DSM's did.
Old 01 Mar 2007, 12:13 pm
mine is the yellow one also !!
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
Traction Control peppy General Turbo Discussions 2 06 Jun 2004 06:35 pm
