Replaced Thermostat &Cap.....
Old 21 Mar 2007, 01:05 pm
Default Replaced Thermostat &Cap.....
and the damn thing still starts to overheat. Goes beyond the midway "normal" spot then the cooling fans kick into overdrive. What can it be? It has a Chrysler t-stat and a standt 18psi cap. I'm at a loss, car has been down for a month as I waited for parts....I NEED 2 CARS!!! Need to get this fixed FAST. Oh, I am stationed in Germany, so parts aren't that easy to get
Old 21 Mar 2007, 05:04 pm
The water has to be moving around thru the system to keep it cool. As it passes thru the radiator, air flow cools it down. if the thermostat has been changed, there's something stopping the flow, meaning a clog somewhere or could be your water pump.
Old 21 Mar 2007, 06:16 pm
What Crewzin said or could be air bound (pocket of air preventing the coolant from moving through the system)if the air was not bled from the system when the new thermostat was installed.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 22 Mar 2007, 02:34 am
Suggestions on how to bleed the cooling system? Any ideas on how to change the main drive belt? I cant find the top bolt on the alternator.
2003 pt/gt deep cranberry metallic
blow-off valve, 2-1/2\" jeg\'s duals, k&n, 215/50r17 coopers, 10\" lightening audio sub, kenwood 5-channel amp, pioneer speakers...stage 1 soon
Old 22 Mar 2007, 10:48 am
i think it might be the water pump [xx(]
Old 29 Mar 2007, 09:34 pm
My p.t kept overheating. It ran fine sometimes but when i would stop the resevoir would leak on to my engine, or it would gurgle. I replaced thermo., rad. cap, fan relays, fan, had my radiator checked professionally, and it still overheated. The last thing on my list was the water pump. They don't leak on the p.t., so you can't be sure untill you check everything. I finally changed out the water pump this weekend, if you have the time and know how you can do it, i did, but be prepared to spend a lot of time, there's no room to work in there. Personally if you have the money, get it done professionally.
Old 29 Mar 2007, 09:40 pm
there is a valve on the bottom right hand side of your thermo, use a #10 socket with an extension ratchet. turn it slightly to the right with the motor running. You should get water spouting out if it's o.k., if there is air in the system then steam will blow out. be careful either way you could get burned. if you get steam, then leave the valve open for a few minutes until water comes out. this may help.
Old 29 Mar 2007, 10:36 pm
Or, do a compression check. A leaking head gasket can cause overheating, even when you don't notice rough running. Used to be you could run the engine with the radiator cap off. When you raced it bubbles would appear. You might try it, but it doesn't work so well with todays closed systems. Be careful! Don't remove the cap when it's hot! [8D]
Bruce
2005 P/T Cruiser
Replaced the whole stereo system added a subwoofer Ctown Sound and Security Forum 7 01 Apr 2006 10:28 pm
Thermostat Replacement SteelBlueGT General Turbo Discussions 9 28 Sep 2005 07:04 pm
New WGA, Thermostat and DSBC Mean Green Turbo Performance 4 13 Mar 2005 04:29 pm
Had PCM replaced and still stumbling... Cal Cruzer General Turbo Discussions 4 19 May 2004 06:30 pm
Replaced under Warranty - PCM and Rack & Pinion skylight General Turbo Discussions 5 19 Sep 2003 02:33 pm
