K&N Air filter install
Old 28 Mar 2007, 11:06 pm
Default K&N Air filter install
Hi Everyone,
Picked up a 06 Convertible two weeks ago and mainly made the choice from a lot of reading on this site, thanks!
Went to change the air filter and notices oil at the bottom of the air box. Also there's a small filter on one side that has oil. Is this normal?
Thanks for any advice.
Alfresco
Old 28 Mar 2007, 11:28 pm
I just picked up my 2006 Convertible on Saturday! I went out to the garage just now to check my filter box, there isn't any oil in mine, but does your car happen to be a turbo? I know some turbo "blow by" some oil, and then that would explain it. Also there is the crank case breather that feeds into the box at that foam filter you are talking about. There could have just been a little extra oil that blew into the box from there too.
I would just clean up the oil, and then keep an eye on the box, and see if it comes back. If it does, there may be a problem. I am not an expert on these things, but I know my way around cars real well. Just clean it up, and keep an eye on it.
Matt
2013 JKUR 10A
2011 Subaru Legacy (Wife's)
Past Mopars:
2006 PT Cruiser Convertible GT
2001 PT Cruiser Limited Edition
1993 Plymouth Sundance/Duster 3.0 litre
Old 29 Mar 2007, 03:28 am
Normal. Just clean it out every so often and wash the foam filter in soap and water.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 29 Mar 2007, 08:55 am
Johns Steel Blue's Avatar
Thread Title states K&N. Is the filter a K & N drop-in filter? If so, there may have been a tad to much oil sprayed on after cleaning. In an K & N recharge kit, there ar 2 components. A spray on cleaner that you allow to stay on for a short period of time and then rinse thourghly. Then apply the filter-oil. It may had had a bit too much applied or put back in just a bit soon.
John
People say I have a drinking problem. I Drink... I Get Drunk... I Fall Down... No problem! ! !
Old 29 Mar 2007, 01:48 pm
All three of my PT's had/have the same thing and so does my srt-4. John makes an interesting point when recharging your K&N filter, make sure it's dry, but I've gotten oil in the airbox when running with the stock filter, too. It's normal in any car out there.
Old 29 Mar 2007, 09:30 pm
I was replacing the stock filter with a new out-of-the-box K&N. It already had the lube job done. I left the stock in and dropped of the PT at the dealer. they'll call maƱana and let me know. Rep said it's something to do with evaporation and some valve could be not working properly. I'll know soon, thank God for them der warranties.
I appreciate all the responses...
Fresco
Cabin air filter AlmondTurbo General PT Cruiser Discussions 44 27 Jul 2012 06:31 pm
Oil & Filter Change. one_fast_pt General Turbo Discussions 13 17 Jan 2004 02:32 pm
K&N filter oil on BTG filter? Punch Turbo Performance 1 15 Oct 2003 11:55 pm
Oil Filter Removal jramosGT Turbo Performance 12 03 May 2003 06:44 pm
