Location for Jack
Closed Thread
Old 29 Apr 2002, 02:18 pm
Send a message via AIM to renichms
Default Location for Jack
In the front, where do you put the jack in order to raise the vehicle and remove a wheel? It may be that my car is too low to see it or a side skirt hides it or something, but for the life of me, I can't find where to put the jack so I don't damage the vehicle.
RN
See Mephisto
Old 29 Apr 2002, 10:23 pm
RN,
It's me, CREWZIN, on my son's computer in Maryland. Your extra body-moldings that you added to your PT between the wheelwells is hiding the welded reinforced lip that's used to support the jacks. That lip is reinforced and strong enough to be used to jack up the PT at either end about 3-5 inches from the end. Not sure how your bodywork is attached or if it will interfere with the positioning of the jack. You might have to use some other stronger points, front and back for your jack points.
Old 03 May 2002, 01:01 pm
Okay...found it now. Just have to wait for someone who can loosen the nuts 'n bolts thingies...then I can get a close look at the calipers and clean them for painting.
RN
See Mephisto
Closed Thread
Meeting location change turbomangt Midwest PT Forum 2 24 Dec 2005 05:05 pm
Tee Location Mean Green Turbo Performance 6 07 Jan 2004 01:41 am
MOPAR Stage I Nameplate Location???? Steve03GT Stage Turbo Kits 18 17 Sep 2003 09:44 pm
MBC location and ECU probs PETEY_CRUISER Turbo Performance 6 15 Jun 2003 04:40 pm
Picture of Turbo Intake Location? bigbrowndog General Turbo Discussions 14 03 Jun 2003 02:06 am
