Driver window opens by itself over night
Closed Thread
Old 02 Jun 2002, 10:10 am
Default Driver window opens by itself over night
Four times now I experienced the following: When I came to my PT (2001) in the morning the driver window was open! The first time I thought I might have forgotten to close it, the second, third and fourth time I was sure it was closed when I parked it at night. I wonder if anyone has had the same strange thing happening.
Wolfgang
PS: email me at cartenoir7@aol.com if you know how this may be caused, I'm still on warranty, but the miles are adding up fast!
Old 02 Jun 2002, 08:08 pm
IT WASN"T ME!! IT WASN"T ME!!
Old 04 Jun 2002, 03:35 pm
SmittysPT's Avatar
From Do It Yourself.com
Follow-up questions and answers for the window issue:
Is it only the front passenger window? YES
Does the PT have the early 2 switches or 4 switches on the dash? 4
Does the window only go down by itself, or does it go up also? ONLY GOES DOWN
Does the window always go all the way down, or does it move in varied increments? ALL THE WAY DOWN
Has it always done this, or is it only recently? LAST COUPLE MONTHS - I'VE HAD THE CAR SINCE LATE AUGUST
How intermittent is it (once a day, hour, minute, week, month)? 3 OR 4 TIMES A MONTH
Are there any modifications to the car (alarm, stereo, etc)? NO MODIFICATIONS
I believe the "Express Down Module" is failing intermittently. It is part of the window switch and the entire switch must be replaced. This should take about 6 minutes of technician time (1/10th of an hour as billed on the work order). Pop out the switch and unhook the 12 pin connector, plug in the new one and it's fixed.
The dealer should be able to bill this under a repair code for "Unable to verify customer complaint" There are "customer satisfaction" codes designed for this situation (the tech can't make it fail). They should order a new switch and replace it without any more than your word and a copy of the diagnosis we just performed. Electrical devices have mysteriously failed ever since Edison's first light bulb blew out.
Smittys PT
Web Designer for
Colorado PT Cruiser Club
Member of PTE,PTCC,PTOC,CPTCC
Closed Thread
Broken rear quarter window! littledog General PT Cruiser Discussions 12 20 Jan 2005 09:20 pm
Weird hatch window replacement problem! SRG Tech & Performance Forum 6 20 Jan 2005 01:39 am
