PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Front end shake
Closed Thread
Old 04 Feb 2003, 07:40 pm
tony tony is offline
Default Front end shake
2001 pt Installed 16" american racing aeros with stock goodyears.
I have a bad shake in the steering wheel very bad above 60 but can be felt at all speeds. Have had them balanced four times.when the car was test drove with stock wheels had the same problum but was gone when bought. Any ideas other than aligment, air pressure,bad tire.
Old 04 Feb 2003, 07:43 pm
bobs turbo pt bobs turbo pt is offline
i was thinking bad tire ??
Old 04 Feb 2003, 07:47 pm
kgdptblue kgdptblue is offline
Tony, might be front disc brake rotors. My 01 is just starting to get a shake (24,000 mi.) but don't care cause I'm trading it in! The rotors are cheap and thin on the 01's and probably the rest as well. At least they claim to have beefed up the rotors on the 03 GT's.
Cruise on!
Old 04 Feb 2003, 07:55 pm
had a shadow in 88 had a shake and it was the rotor !!
Old 04 Feb 2003, 09:52 pm
OurPTGT OurPTGT is offline
Tony, check to make sure there is NO star washer on any of the wheel studs. They come from the factory like that. You have to take them off with aftermarket wheels. It's a common problem. As stated above, rotors are a VERY common problem with vibration. Good Luck!
ps- where you from?
Kevin & Donna's '03 Elec Blue GT
~hood struts
~30% tint
~triple pod w/BOOST/volt & a/f gauges
~XPel headlight protection kit
~ElecBlu vinyl headlight
covers
~ElecBlu flamed reverse light covers
~GT wheel centers
~HeartThrob 2.50" Duals
Old 04 Feb 2003, 09:53 pm
Grouch Grouch is offline
I had the same problem. I put American Racing Estrella wheels on with Stock Goodyears and balanced them 5 different times. They even replaced 1 tire and 1 wheel and I still had it. I put up with it for about 8000 miles and it went away on it's own. I think the mistake I made was to mate a used tire and a new wheel. I think it makes the tire out of round if it has been on another wheel. I figured I would have to scrap the tires but at least now I can wear them out. I would never switch a tire that had been on another wheel again
Old 04 Feb 2003, 09:57 pm
keep us posted !!
Old 04 Feb 2003, 10:15 pm
Bosch Bosch is offline
Send a message via AIM to Bosch
Also make sure that the front Axels are ok. I have heard that they can cause vibration problems too...
Driving a 2001 27F Patriot Blue!
Old 04 Feb 2003, 10:59 pm
if the Axels are bad wouldn't have been bad before?? just a thought
Closed Thread
vB code is On
Front license plate placement spicy pt Exterior & Interior Styling 39 04 May 2008 11:15 am
Please help, front end shimmy survey Boomer Tech & Performance Forum 11 28 Mar 2005 01:33 pm
camber alignment kit needed for front ??? boosta Turbo Wheels/Suspension/Handling 7 10 Jun 2004 11:25 am
Front end shake THANKS tony General PT Cruiser Discussions 5 08 Feb 2003 02:39 am
2002 Crusier Front end shake American flyer Tech & Performance Forum 3 09 Oct 2002 03:26 am
  Flights | Business Credit Card | Best Credit Cards | Problem Mortgage | Mortgage Calculator
