Rear end thunk
Closed Thread
Old 02 Jul 2003, 12:20 am
Default Rear end thunk
Yo,
I know the answer to this is in the PTE archives, but I can't seem to access them right now
Going over small bumps, I hear/feel a substantial thunk/thump coming from the rear seating area. I seem to recall some PTE folks experiencing something similar and it turned out to be a bushing in the Watts linkage. Yes?? I have about 1500km left on my warranty, so I better get it taken care of asap.
BTW, when I grab the rear wheels and push or pull on them hard I can hear/feel something. I seem to recall this being a way to diagnose the problem. Just looking for confirmation on this.
Thanks.......Brad
Old 02 Jul 2003, 02:19 pm
If you can grab the wheel at 6 and 12 and you feel just see/feel just the wheel move as you push/pull top and bottom, this is usually an indication of a bas bearing.
Old 09 Jul 2003, 02:01 am
Ya, so anyways, I took the car in for some other warranty work...mentioned the noise. They said they have had that problem in before. WAS the bellcrank(watts linkage)bushing. Mine is an '01 LTD, 60k km.
Cheers......Brad
Old 12 Jul 2003, 03:58 pm
Send a message via AIM to Gary C
This is interesting. I have the same clunk sound coming from the rear end of my GT cruiser, but with only 12,000 miles on the odometer. Unfortunatly now there is also a lound CLUNK coming from the front seemingly every time I go over a bump, I get a clunk from the front end, then as soon as the rear tires go over i get a second clunk.
It's starting to annoy me. [V]
If I would have known my daily driver 'hot rod' was going to give me as much trouble (if not more) than my *real* hot rods I probably wouldn't have gotten one. [:I]
2003 GT cruiser
209HP 248lb/ft SAE corrected
Old 12 Jul 2003, 05:23 pm
Gary, You have the lights flickering and a clunk from the front and rear....sound like you picked yourself a lemon. Hope you get it all straightened out.
Old 12 Jul 2003, 06:50 pm
and it will be going back for the second throw out bearing in 10,000 miles. The first one was done under that recall they issued, and the second one only lasted ~5K before it started to happen *again*.
The funny part is the tech whom i spoke with said he's not suprised as I was (unfortunatly) one of the first and probably recived the same bad throw out bearing batch that was in there. [xx(]
OH well. That said I still love the car, I just *HOPE* they get it taken care of as it will be it's 4th trip in for transmission problems, and now the thunk up front and in rear.
On another random note i pulled my spark plugs today )after having the stealership check out the misfire and problem with idling. Sure enough they were gaped at .060!! [xx(]
I think I just may have a case of *bad* luck.
2003 GT cruiser
Closed Thread
Rear Hatch Opener Install ? StevenAndEva Sound and Security Forum 1 24 Feb 2006 12:23 pm
Thunk in rear gonzomania General PT Cruiser Discussions 1 28 Jun 2004 08:22 am
Replace/install both sway bars or just rear? im4gzs Turbo Wheels/Suspension/Handling 11 23 Feb 2004 09:11 am
Rear door sill scuff pads stronda Interior Accessories Forum 5 04 Sep 2003 05:46 pm
Rear anti-sway bar install on GT JohnM General PT Cruiser Discussions 11 24 Jul 2003 07:38 pm
