cracked windshield
Closed Thread
Old 22 Jul 2003, 12:52 pm
Default cracked windshield
Any ideas how I should approach this with the dealer, if at all? - - - We were driving along and a crack appeared in the bottom center of the windshield, and it grew before our eyes to about eight inches long. No sign of any rock damage, and we didn't hear any.
Old 22 Jul 2003, 01:30 pm
i'd take it to a glass specialist for an opinion.
no way a dealer is going to take responsibility unless someone points the finger at them.
plus it just sounds very odd. any tempature changes happening in your area?
you may have to eat it up through your insurance....
\"keep your stick on the ice, and your minivan in the right lane.\"
Old 22 Jul 2003, 11:05 pm
If There is no rock damage take it to the dealer and if you have a decent desler they wil replace it without any problem but make sure you look really well that there is no rock damage.
Greg Gavencky
The New Jersey Cruisers
www.njcruisers.com
Old 22 Jul 2003, 11:46 pm
There have been noted problems with the Cruiser winshield and stress. If the dealer doesn't take care of it your insurance will. Matter of fact the insurance people are pretty good at things like this. They will not let the dealer BS you.
Old 23 Jul 2003, 10:09 am
quote:...If the dealer doesn't take care of it your insurance will...
Also recommend that you check with your dealer first then with insurance company. Either way it should be taken care of with little or no problem. Good luck.
Old 23 Jul 2003, 10:36 pm
Thanks, people.
Old 24 Jul 2003, 11:56 am
see if you can find any other people that have had the same problem this way you can prove it to the dealership good luck !!
Old 24 Jul 2003, 12:14 pm
This is from the PT Do It Yourself site:
Windshield Damage and Repair Issues
Some PT owners have reported problems with their windshields. The issues generally fall into two categories: stress fractures and road debris damage.
Stress Fractures
Stress fractures can occur in a number of ways. A faulty windshield installation and or parts can result in stress fractures, as well as normal settling within an unibody-constructed vehicle like the PT.
During the early 60's every Chrysler vehicle, except Imperial, underwent a radical reengineering to unibody construction. This major advance resulted in bodies with greater structural integrity than the traditional body-on-frame method. Unibody construction, also referred to as "integral frame" construction, is a manufacturing process where sheet metal body parts are combined with stress-bearing elements to form the body and chassis as a single piece, as opposed to attaching body parts to a frame. Other than strength, this method also provides savings to manufacturers in weight and materials. Based on the same principal as aircraft construction, stresses are more evenly distributed throughout the structure. U-construction is best-utilized with smaller vehicle platforms.
The windshield is a stressed member and part of the unibody support structure. Over time, as the vehicle settles, additional stress may be placed on the windshield, doors and rear hatch. You may also notice that the doors close differently (tighter / looser) as time goes on. If the windshield has any nicks or defects in the edges (generally hidden by fascia moldings) it may fracture. Normally, this settling process is accomplished during the first few months of normal vehicle use.
Stress fractures are covered under your vehicle warranty provided that there is no evidence of chipping. One test that a dealer may use to make a determination is to take a pointed object such as an ink pen, and run it along the length of the crack. If the pen does not hang on anything, than it is deemed to be a true stress fracture and not a fracture, which began with a stone chip.
Road Debris Damage
There have been a fair number of complaints from PT owners who feel that the windshield is susceptible to an inordinate amount of chipping and pitting damage from various forms of road debris. Some suggest that the windshield is of poor quality and chips and pits easily, while others believe that the problem is exasperated by the front-end design of the vehicle.
Unfortunately, windshield damage statistics are not encouraging. According to the auto glass repair industry there are more than 230 million vehicles in the U.S. and one out of every seven vehicles on the road has repairable windshield damage. You have better odds of receiving rock chip damage to your windshield than a flat tire. As a whole, that's a good deal of damage, however their is no current data to support or deny the notion that PT's sustain a larger percentage of windshield damage than other vehicles.
Repair or Replacement?
The decision to repair or replace a damaged windshield is based upon a number of factors and is usually guided by your dealer or a qualified auto glass repair facility, who will also determine if the damage is covered under your vehicle warranty. If the repair or replacement is not covered under the warranty, it will be covered under the Comprehensive section of your automobile insurance policy, assuming that you have coverage. If you financed your vehicle, the loan provider probably requires you to carry Comprehensive coverage until the loan is repaid. Depending on your policy deductible, you may or may not have out of pocket expenses for the repairs. It's also a good idea to check your coverage with your insurance company as it applies to state law. Some states have enacted laws to protect the consumer and require insurance companies to waive the deductible if you have your windshield replaced, and guarantee you the right to choose the repair facility of your choice to repair your vehicle.
In the case
Turbos rule Others drool
Old 27 Jul 2003, 06:05 pm
That sucks
I'll trade you my windsheild for your gas tank.[B)]
Would you like some slightly CHEWED hoses? [8]
How about a brake caliper bolt?[:0]
Will you be at the picnic?
Good Luck bud...[^]
KB
Old 27 Jul 2003, 08:34 pm
OurPTGT
they invented things called "snacks" to prevent people from knawing on things within arms reach eh....
or does this --> [8] <-- mean you got the munchies and couldn't help yourself??
Closed Thread
stressed windshield zoned Tech & Performance Forum 6 08 May 2005 08:04 am
Windshield Glass 2step General PT Cruiser Discussions 5 23 Oct 2004 11:04 pm
Cracked Windshield RobGT General PT Cruiser Discussions 8 05 Feb 2004 11:55 pm
relocate windshield washer rnbenoit Exterior Accessories Forum 6 03 Aug 2003 11:22 pm
Windshield Cracked MichaelDay General PT Cruiser Discussions 2 18 Jul 2003 01:24 pm
