stering wheel noise
Closed Thread
Old 15 Aug 2003, 09:29 am
Default stering wheel noise
I read somewhere in the fourm (can't find it though) on people experiencing a noise when turning the stering wheel. Don't know if its a problem with all cruisers, certain years? or turbo's. In any event, mine just started doing it. anyone know what the fix is? Thanks gary
Old 15 Aug 2003, 10:57 am
Gary, there have been two problems identified. On some the clockspring in the steering wheel had to be replaced. This was a clicking noise. Since last summer, a rubbing or squeaking noise when the wheel was turned has been showing up. The fix for that seems to require the replacement of the rack and pinion. Dealers seem to be handling it under warranty but some are trying other fixes, such as "special" steering fluids, etc first. Those "special" fixes do not work and after a few trips to the dealer they will end up having to order the rack and pinion unit.
Old 15 Aug 2003, 11:14 am
Thanks, mine seems to be the squeaking and rubbing. I hope they do the right thing first, its a hassle going back and forth.
Old 15 Aug 2003, 11:36 am
Hmmm... I have been experiencing a 'creaking' noise from my steering wheel just lately, but only when I go to full lock in either direction. This noise definitely seems to be coming from the steering column as it really noticeable inside the car.
I mentioned it on my last service and after the service they told me they were ordering a replacement steering column and that they would call me when the part came in. Are the noises others are experiencing coming from the same area as mine, or is this something else again?
Inferno Red 2002 Limited Edition. Minor modded. VA tag \'HOT CRSR\'
Old 16 Aug 2003, 09:23 pm
As MichealDay says, there are apparently two different problems. I recall a few months ago another forum I used to follow had multiple reports of a "popping" sound within the column itself which were traced to faulty bushings. Replacing the column was the solution. There are also at least three Tech Service Bulletins for steering column noises: 1900601, 1900601A, and 1900702, so DC is aware of the problem(s). Good luck!
Old 17 Aug 2003, 06:08 am
Try unlocking the tilt and moving the wheel up and down. It worked for me.
Turbos rule Others drool
Old 27 Aug 2003, 11:30 pm
Great Info!
I noticed the sound coming from the steering column (like a rubbing sound) about a month ago (10,000 miles).
I'll try unlocking the tilt before I complain.
Thanks!
\'03 PT Turbo 2CN
Auto/Stick
Lt. Almond/cloth
Blanes HoodStruts
etc.
Old 28 Aug 2003, 05:30 pm
We've noticed a "rubbery squeak" when we turn the wheel in Prudence ('01), as well. Sounds like two rubber gaskets sliding against each other, almost like it's part of the interior trim around the steering column or something like that. Hope it's not the rack-n-pinion problem! Taking her in to have them rotate the tires next week, and I'll ask them to check it out (and I will definitely go armed with the TSB numbers!)
beebs
Old 29 Aug 2003, 12:08 pm
is chrysler admitting that there is a problem with them?? or do people get the run around from there dealership about it??
Old 29 Aug 2003, 12:55 pm
skylight's Avatar
Administrator
Just took mine in for the rubbing sound. They ordered a rack and pinion, under warranty.
Closed Thread
Noise from Left Wheel neps Wheels, Tires, Suspension 1 02 Aug 2004 01:00 pm
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
New Steering Wheel at Jegs nhrapt Interior Accessories Forum 2 24 Feb 2004 01:03 am
Stering wheel noise returned turbomangt General PT Cruiser Discussions 7 02 Nov 2003 12:51 pm
Need help fixing a lug bolt. KurtPT Tech & Performance Forum 4 12 Aug 2003 06:03 pm
