differant oil filter
Closed Thread
Old 19 Sep 2003, 12:48 am
Default differant oil filter
Changed oil in the gt today and found a differant oil filter than my 01 had. Just seems to be longer with the same thread and oil seal face. I put the shorter old fram 3614 on the gt today due to the fact that I have some left over and they seem just less capacity.If anyone know if there is a problem using the shorter please let me know. It will surly be easier to remove it next time. Other than length I see no differance in them. Flash
Installing tubo grade 1 upgrade tomorro
Btg axle back in shipping
Old 19 Sep 2003, 09:35 pm
You have significantly more square inches of filter surface and a small amount more oil in the correct 3600 filter. Personally I would not go out and pull the filter you just put in but certainly would get the larger one for future changes. I would even recomend non turbo owners to use the bigger filter.
I have since back in the 70's always researched a cross reference to a large filter on every car I have owned. The 3614 filter called for on the NA PT's was also the spec'd filter on my 2.2 turbo Daytona's and my 89 Dakota pick-up. In both those cases I had the clearance to use the PH8A filter which holds a full qt of oil. It's worked for me; 240,000 miles on my first 2.2 turbo, 176,000 on teh one the PT GT replaced and 246,000 on my 89 Dakota.
Dave Clement
\'03 GT, Electric Blue
Closed Thread
Cabin air filter AlmondTurbo General PT Cruiser Discussions 44 27 Jul 2012 06:31 pm
Whats up with factory oil filter yotehunter General PT Cruiser Discussions 10 09 May 2005 08:28 am
Oil & Filter Change. one_fast_pt General Turbo Discussions 13 17 Jan 2004 02:32 pm
K&N filter oil on BTG filter? Punch Turbo Performance 1 15 Oct 2003 11:55 pm
Oil Filter Removal jramosGT Turbo Performance 12 03 May 2003 06:44 pm
