Kammler68
Closed Thread
Old 01 Oct 2003, 01:05 pm
Default Kammler68
Didn't want to hijack Cyanjag thread, so here's gauge pod info for you.
this is the post where tthrift talks about his gauge pod9this is not the same link you gave me. He said it was an autometer triple gauge pod that he got at www.summitracing.com part # 17215.
link http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=3500
As far as the gauges themselves, you can get them at any chrysler dealer or you can email tthrift at tthrift@haynesjeep.com he's a parts manager for chrsler/jeep. He'll have all the info and he has all the part #'s for the gauges and he answers emails quickly.
or here's the post where Jody has links to the flyer Mopar put out with part # and prices http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=2873
That's should be what you are looking for, if it's not than [:I]
Old 01 Oct 2003, 01:25 pm
also with the triple pod, and three guages installed thats alot of wiring. I used bullet connectors so I could remove the pod if required.
some tips are:
bullet connectors for all wiring.
leave some slack so you can pull out the guages after install, to change the bulbs etc.
buy an add-a fuse from the autoparts store (mini)
in my a-piller there is an orange wire ( I think its to dim the overhead consol)
to run the boost-guage tube through the firewall locate the hood relaese wire from inside the engine bay, poke a coathanger through the rubber grommet, tape your boost guage hose to the end that comes into the car and pull it through.
a good ground is the 2 screws holding the fuse panel to the car in the dash.
for air/fual guage you will need a seperate o2 sensor, can be bought from summit.
Punch, has all wiring done, and guage pod going in today.
Old 01 Oct 2003, 08:32 pm
I knew if I whined enough someone would save me from myself. A very sincere thanx Rice.
See that Cyanjag. We got helpful folks here too.
Closed Thread
