PT Cruiser Forum Car Videos
Car Rims
compression fittings?
Closed Thread
Old 02 Oct 2003, 01:27 am
Punch Punch is offline
Default compression fittings?
ok installing my boost guage came with a compression fitting, looks like this two peice brass part, with a small brass (ball) inside with a hole in it.
I have a 1/8" nylon hose that fits into this brass compression fitting, how the heck does this work, it doesn't hold the hose, etc...
thanks
Old 02 Oct 2003, 03:04 am
BL CRUZR BL CRUZR is offline
When you tighten the fitting it compresses the ferrule (ball with hole)to grip the tubing. Only tighten it about 1/2 to 3/4 turn after it is finger tight or it will damage the ferrule and the tubing. Hope this helps.
John
2003 GT Silver, factory flames, pinstripes, BTG duals, stage 1, 3 silencers removed, K&N dropin, Suspension Techniques sways, BTG strut brace, 17X8 Sport Edition wheels, Yokohama 245-40 AVS ES100 tires, RED calipers, Hidden Hitch
Old 02 Oct 2003, 12:10 pm
am i supposed to be able to fit the hose through the ferrule?
Old 02 Oct 2003, 12:57 pm
P.S. If the ferrule has been compressed once it can't be reused. You should be able to get a replacement at a hardware store if this happens.
Old 02 Oct 2003, 12:59 pm
If everything is the right size, yes. Is the hose semi-rigid?
Closed Thread
vB code is On
Compression fittings on terminals 2step Sound and Security Forum 4 15 Jan 2005 05:02 pm
compression fittings Punch Exterior & Interior Styling 10 11 Nov 2003 10:36 pm
who was it that sent me fittings? Punch General Turbo Discussions 2 15 Oct 2003 09:13 am
grease fittings RickMe Tech & Performance Forum 3 07 Oct 2003 06:27 pm
grease fittings RickMe General PT Cruiser Discussions 1 07 Oct 2003 06:23 pm
  Online Image Resizer | Problem Mortgage | Celebrities | Myspace Comments | Mobile Phone
