Prudence just turned over 11,000 miles. Was changing the oil last week, and noticed oil on the passenger side ("front" end) of the engine, and put my hand up inside the plastic shroud at the right side and front of the oil pan and felt the side of the engine and fingers had oil on 'em. Doesn't appear to be dripping really bad yet, but at least "seeping" enough to collect on the plastic shroud and get coated with dust/dirt. Anyone else have oil leak probs with an '01? Anybody know what it might be that's leaking?
beebs |
I would suspect that your oil pan is seeping. I would thoroughly clean it and dry it then run the engine and use a bright light to look for the leak. It may be a simple matter of tightening the pan bolts. You might also look to see if your oil pressure sender is seeping.
Thanks for the suggestions....we're gonna give the car a bath this weekend, and I'll clean the area with the oil/dirt buildup then. If oil leaks are covered under the warranty, I'll take it in to the dealer on Monday and let them take care of it.
beebs Quote:
Are you sure its not spillage from re-filling the oil from the last oil change? I ask because I spilt some lst time I did I changed the oil, then about a week later, it made its way down to the undercarriage!!
Also, check the colour- if its RED< it may be tranny fluid and/or power steering. Good luck
------------------- 2001 Patriot Blue 5 spd LE 2007 Black Dodge Caliber R/T AWD 2009 White-Chocolate Platinum model F150 Supercrew 4X4 |
beebs |
| AC oil leak | robinjoe | General PT Cruiser Discussions | 4 | 16 Sep 2005 03:38 pm |
| ATF leak? | calicranberry | General PT Cruiser Discussions | 7 | 19 Jun 2005 12:00 pm |
| tranny leak | steve smith | Tech & Performance Forum | 1 | 17 Jun 2005 05:08 pm |
| Oil Leak | PT Woody | Tech & Performance Forum | 10 | 21 Jan 2005 12:43 am |
| Leak Detection Pump | CHROMEDCRUISER | General PT Cruiser Discussions | 13 | 06 Aug 2004 04:07 pm |
