Safe jacking
Closed Thread
Old 04 Nov 2003, 12:20 am
Default Safe jacking
There seems to be a lot of confusion and concern about the proper and safe way to jack up a PT. Many people have been jacking up the entire car and placing it on 4 jack stands. I BELIEVE THIS IS UNSAFE. I wanted to start a thread on this subject so that we could share advice on safe jacking methods.
Please post your ideas on this very important safety issue.
Old 04 Nov 2003, 12:33 am
Just paint or jack up one wheel at a time...
Or use ramps
Or jack up and put on stands only 1 axle at a time...
Homepage:
Old 04 Nov 2003, 12:49 am
Agree with GTSteve and PTGT Redman, even then I'd be carefull with the rear. Before lowering, the points where I placed my jackstands on the rear (where the tie down tabs where located) required the jackstands to be set at their maximum height. Maybe there is a better location on the rear but I didn't see one.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 04 Nov 2003, 03:59 am
I agree. I just painted my calipers this evening and took GTSteve's suggestion to heart. I only used 2 jackstands, did the front first and completed the process on the rear. This is by far the safest way to go. Thanks again for your suggestions it really helped.
<b><font color=\"red\">2003 LT ALMOND GT</b></font id=\"red\">
<font color=\"blue\">MODS:</font id=\"blue\">
Stage I, Custom Pin Stripe, Rear Spoiler, BTG Polished Strut Tower Brace, Borla 2.5\" CAT Back Dual Exhaust, and AirAid Intake System, Polished Front & Rear Sill Plates, Chrome Antenna Bezel w/10\" Chrome Billet Antenna, Mobil 1 and K&N Gold Filter, \"Flame\" 3rd Brake Light, \"Streamline Design\" PT Cruiser Visor, Rear Shelf Graphics and Dash Dots on Steering Wheel, and MGW \"GT\" Auto Shift Knob,Chrome Door Lock Pulls, Chrome Billet A/C Knobs with Acrylic Red Inserts, Chrome Oil Cap, Chrome Dip Stick, Chrome Radio Knob, Blane\'s Hood Lift Kit. Chrome Raidiator Coolant Bottle Cover, Timing Belt Housing Cover, Shock Tower Covers w/Nuts, Power Brake CYL Cap Cover, Windshield Washer Cap Cover, A/C Line Connector Cap Covers, A/C Check Valve Cap Covers and Radiator Cap Cover. \"GT2\" Rolo Red Calipers, Magnecor 8.5mm Spark Plug Wires - Red, Red Wire Looms, Billet Aluminum Steering Wheel Caps (4), Chrome Coin Tray Trim Cover, Chrome Shifter Bezel Tirm Ring, Yoko AVID V4S - 215/50/70\'s, TYC Euro Style Back-up Lights, and Screamin Demon Coil
Old 04 Nov 2003, 08:58 am
LT Almond, where did you place your jackstands in the rear?
Mercedes Wiki
Old 04 Nov 2003, 09:10 am
Send a message via AIM to sakigt
Use a lift or just use 2.
14.67 @ 94.5 &lt;--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 04 Nov 2003, 11:48 am
In the rear I placed the jacks on the trailing arms. It worked great and is wide enough to support the caron the jacks.
Old 04 Nov 2003, 11:52 am
one side at a time, never the whole car up in the air!!
Old 04 Nov 2003, 01:26 pm
I use professional jacks and still back them up with heavy duty stands.
Old 05 Nov 2003, 04:31 am
2sb 2sb is offline
Up on 4 jack stands is safe if it's done in a safe manner.
Having only one wheel off the ground is unsafe if it's done wrong.
I wrote the whole process on my preferred way for raising a PT a while back but I don't know where that thread is.
Mainly I prefer 6ton stands for the width of the base. And after setting the vehicle on them, I try to rock it some to make sure it's stable.
When working with RWDs, you need 20-24" for trans removal and stuff.
I'm 57 yrs old and basically paranoid. I'm also fond of my body and prefer to avoid damage to it and/or pain. If I didn't feel the odds were well in my favor, I'd never slide under a vehicle.(I worry more about some of the entrance ramps around town.)
If you're not familiar with working with stands, have the help of someone who is...
and is not an idiot.
Closed Thread
