cruise control
Closed Thread
Old 29 Dec 2003, 06:42 pm
Default cruise control
Still haven't got my owner manual.
I push in on the cruise control and the "cruise"light comes on-press down on the lever to set but does not engage.Checked fuse-o.k.
Am I not setting it right or do I need to visit the dealer[xx(]
Any site w/online manual?
Says 3 more days till Fla.
Old 29 Dec 2003, 07:13 pm
Cruise Control: To Activate - Push the ON/OFF button. The Cruise indicator in the instrument cluster will illuminate. To turn the system OFF, push the ON/Off button a second time. The Cruise indicator will turn off. The system should be turned OFF when not in use.
To Set At A Desired Speed: When the vehicle has reached the desired speed, press down on the lever and release. Release the accelerator and the vehicle will operate at the selected speed.
NOTE: When in the AutoStick mode, speed control will only operate in third and fourth gear.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 29 Dec 2003, 08:45 pm
I always push in and push down, then up to engage. I know it just says down.... Once engaged, up taps will increase speed a mile or two per tap.
Old 29 Dec 2003, 08:48 pm
Thats what I thought-looks like there is a problem.Back to the dealer[xx(][xx(]
the big grin would rather go to the dentist than the dealer-his NO2 doesn't void thewarranty
Old 29 Dec 2003, 08:51 pm
sounds like you will have to bring it in
Old 29 Dec 2003, 09:27 pm
Question Cook, Why didn't the dealer give the manual to you. Every vehicle I bought had one. My used PT had two in the dash compartment, and NO, one isn't yours.
Old 29 Dec 2003, 09:47 pm
Send a message via AIM to Rolo
LOL!
Did you check the throttle connection to the cruise control?
Old 30 Dec 2003, 09:36 am
Rolo-haven't a clue what to look for[:I]but I'll learn-let the dealer take care of it for now.
Hooligan-he gave it to me at the lot-was reading it in the office-signed a bunch of papers-getting late -left it there-was mailed sat. to me-should be here today(tue)
The big grin can't believe cook fell for the"its in the mail"
Closed Thread
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
Cruise Control Glitch gtbright General Turbo Discussions 0 12 Feb 2005 08:36 pm
