PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
trany fluid question
Closed Thread
Old 20 Jan 2004, 11:57 am
Jimbo Jimbo is offline
Default trany fluid question
This seems like a stupid question that I should
know the answer to,but I really don't.
How long do you have to let your car run
before the trany fluid should be between
the upper dots on the stick.the reason I
ask had some trouble with a ford i had ,thought
it was hot enought and added fluid than I had to much
in and had to drain it.
Old 20 Jan 2004, 12:13 pm
Not a stupid question, should be spelled out in owner's manual. From another (earlier) Chrysler product I remember something like - run the car 'till temp gauge is in normal range. Put transmission lever thru all the gears - PRNDL - etc. It gets pretty specific. Be sure the car is level, too.
Old 20 Jan 2004, 12:18 pm
IRPT IRPT is offline
quicksliver is correct, I believe the owners manual states to run the car for 15 minutes prior to checking the fluid, and put the transmission lever thru all the gears, as quicksilver stated, ending in park.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 20 Jan 2004, 01:04 pm
MX-5 MX-5 is offline
Minmum fluid temp is 180F.
Old 20 Jan 2004, 06:21 pm
SteelBlueGT SteelBlueGT is offline
Ok I will bite how would U know what the temp is MX-5??
Old 20 Jan 2004, 06:58 pm
OurPTGT OurPTGT is offline
This might for those with a TRANNY TEMP gauge[:I]
Old 20 Jan 2004, 07:09 pm
JaxPT JaxPT is offline
make sure you replace it with the right fluid. I read some stuff about major problems using other kinda of tranny fluid http://www.allpar.com/fix/trans.html
"All Chrysler four-speed automatic transmissions* are very sensitive to the quality of the transmission fluid. Only use Type ATF+4 in these transmissions. Do not use Dexron or Mercon."
Old 20 Jan 2004, 07:39 pm
Because the transmission fluid temp sensor transmits real-time data to the professional scanners I use.
All shifting is based on trans fluid temp and CVI-calculated volume index.
Old 20 Jan 2004, 08:28 pm
bobs turbo pt bobs turbo pt is offline
thanks jaxpt!! good info
Old 21 Jan 2004, 01:46 am
skeeter1620 skeeter1620 is offline
they also make an aditive called lube guard .when combined with dex3 will equal chy+4
2003 Dream cruiser 2 #1434
mopar bov and k&n drop in filter ,billet shorty antenna, silencers removed, custom painted rear shelf that says\"Dream Cruiser II\"and maybe, doubtfully soon------stage 1
Closed Thread
vB code is On
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 4 06 Jan 2006 07:12 pm
I think my tranny's about to go! TaylorMade Tech & Performance Forum 25 01 Apr 2005 12:46 pm
Power Steering Fluid jmack General PT Cruiser Discussions 9 17 Nov 2004 06:52 pm
Fluid coming out of exhaust... crazie.eddie General PT Cruiser Discussions 10 11 Nov 2004 04:21 pm
Washer fluid ssbandit19 General PT Cruiser Discussions 1 27 Sep 2002 03:20 am
  Debt Help | Mortgages | Loans | Cheap Car Insurance | Free Ringtones
