uneven acceleration
Closed Thread
Old 22 Jan 2004, 06:30 pm
Default uneven acceleration
long time reader....thanks to you all for the many ideas....now I need some advice....2003 pt gt...24K, in great shape...BTG intake, BTG springs,BTG strut tower brace...lots of added chrome...etc..in the last 2 weeks with both the cruise contol on and off, and at various speeds the engine will accelerate on its own for a second or two at a time..then resume normal operation......no missing, but a very brief but noticeable acceleration, like the motor is looking for another gear...then resumes...most noticeable at 2500...70 mph with the cruise on....should I reset the computer...if so....how do I do that?.....any suggestions would be most welcome....thanks again...and for all the past info...Jim
Old 22 Jan 2004, 06:42 pm
Mo-Cash,
Welcome to the forum. You hit the nail on the head with the easiest solution...reset the computer. If you've installed or played with the modifications you described, you know how to access your battery. Find the negative cable and unhook it from the post. Leave it off for a few moments and then re-attach it. The car might stumble a bit when starting and running for a few minutes while it re-learns the settings. Take it for a ride and go thru all gears and go as fast as they legally permit in your area. Then try the cruise control again. If it still does the surging, You have a bad cruise or you might have a vacuum leak somewhere. Good luck.
Old 22 Jan 2004, 07:31 pm
mo-cash, welcome to the forum! Take CREWZIN's advice (it's good) and let us know the outcome.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 22 Jan 2004, 08:05 pm
welcome mo cash, do just as crewzin says
Old 22 Jan 2004, 11:53 pm
Welcome to the Forum, mo-cash, the above ideas are the best to start with, at least. Let us know how it goes. [^]
Closed Thread
spark knock sound under any acceleration Steve Clark Tech & Performance Forum 20 19 May 2011 07:01 pm
Parking Brake Light upon Acceleration JohnM Tech & Performance Forum 5 27 Jan 2006 09:07 am
Pinging on acceleration coolvanillagt Turbo Performance 24 15 Oct 2005 04:08 pm
Shimmy on initial acceleration Boomer Tech & Performance Forum 8 16 Mar 2005 01:43 pm
Best Shifting For Acceleration??? kidturbofan Turbo Performance 7 13 Sep 2003 02:43 pm
