windows won't go down
Closed Thread
Old 29 Jan 2004, 05:10 am
Default windows won't go down
Has anyone had trouble with the windows not
going down in cold weather.Went to the bank
the car was cold and it was 0 outside, the drivers window
would not roll down. After the car warmed up they
worked fine.
Old 29 Jan 2004, 08:23 am
I have had mine work in -F temps as long as windows are clear. Could there have been ice on the window? If there's ice, no, it won't open.
Old 29 Jan 2004, 09:16 am
no ice
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 29 Jan 2004, 01:55 pm
This is what may have happened. When the inside of the car is warm and the outside is cold a bit of moisture condensation occurs on the inside of the glass, especially around the edges between the glass and the rubber weather seal. When the car is sitting empty and not heated in very cold temperatures, the moisture between the glass and the weather seal freezes and won't let the window go down, even a power window. When the car warms up the ice melts and the windows work again.
Old 29 Jan 2004, 04:44 pm
Very good answer!!!
Old 29 Jan 2004, 07:51 pm
none of the windows or just the drivers side??
Closed Thread
holy crap !! cleaning windows!! what to use?? bobs turbo pt The Detail Shop 7 16 Sep 2005 09:33 am
windows up/down with A/C on/off bigdogdad Tech & Performance Forum 1 09 Aug 2005 05:02 pm
rear windows rattle gonzomania General PT Cruiser Discussions 6 06 Dec 2004 03:03 pm
Windows Paintball3r The Detail Shop 19 11 Nov 2004 10:43 pm
Front Windows Tinted yobiebs Exterior Accessories Forum 13 16 Aug 2003 11:22 pm
