removing door pillars for painting
Closed Thread
Old 16 Feb 2004, 02:18 am
gonzomania's Avatar
Send a message via AIM to gonzomania
Default removing door pillars for painting
I've looked at the d/y/i page and the chiltons manual and Pt service Cd to get to the three screws behind the weatherstriping to remove the door pillar applique. You must move the weatherstriping out of the way. Has any one done this, do you just pull the weatherstriping out, roll it away from the exterior. Afraid of loosening the striping an not be able to reattach it. Any help would be appreciated.
Gonz
Old 16 Feb 2004, 02:30 am
Gonz
I've done it. Just pull the weather stripping out of the way. It goes back on easily, I used a rubber mallet to ensure it was firmly back in place. Don't know if this will help any, check out this link, I took some photos while I did mine.
http://www.randgraphics.org/PT_Cruis...r_applique.htm
2002 Inferno Red PT Limited
Mercedes Wiki
Old 16 Feb 2004, 02:36 am
Send a message via AIM to Rolo
hehe, I went through the same thing (fear of breaking something) and why I bought the Service Manual.
After you remove the runner, you just pull out the weatherstrip; it is all one piece.
Use a magnetic driver on the screws and tuck cloths in the door to keep you from having to remove the door panel if you were to drop a screw.
What the manual did NOT say is that there are plastic shims glued to the top of the pillar that can snap off (at the glue) during pillar removal. Look out for that piece so you do not lose it.
Old 16 Feb 2004, 02:40 am
haha, IR! Hmm...we need to work out schedule, we keep replying at the same time, lol.
hehe, I see you had the plastic shim fall off too!
Did you paint yours? I wanted to paint mine to match the glass and wondered which would be the best black for it.
Old 16 Feb 2004, 02:46 am
gonzomania's Avatar
Thanks guys, great info!!!!!. As soon as weather breaks I'm getting aeroskirts kit and painting pillers to match Light Almond Pearlcoat.
You guys should give your links to ask Motor Mike (ed Junod) on D/y/I Link
Gonz
Old 16 Feb 2004, 03:00 am
Haven't painted them yet. After I took them off the weather did not cooperate, waiting for spring then I'll paint them.
BTW, super glue works great for gluing the little plastic pieces back on.
Mercedes Wiki
Closed Thread
Removing intake manifold Franksredpt General PT Cruiser Discussions 10 22 Sep 2007 02:16 pm
Removing Oversprayed Clearcoat TripleJackInGA The Detail Shop 6 06 May 2004 07:16 pm
removing electric window switch gonzomania Interior Accessories Forum 10 16 Mar 2004 07:40 pm
Removing Swirls turbomangt The Detail Shop 3 26 Feb 2004 02:52 pm
removing cat kruzzinpt Turbo Performance 3 06 Aug 2003 10:00 pm
