How do i get power to and wire neons from fuse box
Closed Thread
Old 20 Feb 2004, 12:50 am
Send a message via AIM to CruiserDan
Default How do i get power to and wire neons from fuse box
Ok here is my problem, i want to use the fuse box to supply power to my neons in my car, i have several sets and how am i to go about this by taping into the fuse panel in the car. I have an 02 touring edition without heated seats so i thought in the place where that fuse goes.
Any one wire them this way, im trying to make it as simple as possible without taping into say the 12v outlets or batery direct.
so please share on how u did it.
Cruiser Dan
Old 20 Feb 2004, 01:41 am
insane1
Guest
Posts: n/a
they sell fuse taps for this.
Old 20 Feb 2004, 09:37 am
Or, you can take a fuse, break away the plastic to get at the metal lugs, and solder to them. Be sure to use an inline fuse. Easier than getting at the back of the fuse block.
Old 20 Feb 2004, 10:31 am
Send a message via AIM to ptcruzin42
i thought neons required a 12v power sourced such as a battery?? [:I]
Life dealt me a hand and I\'m bluffing hard, I\'m playing poker with a joker and some uno cards.
Old 20 Feb 2004, 01:16 pm
I ran my neons off the battery. Its really not that hard just put the wire right through the firewall and connect all them up.Good luck with everything.
03, onyx 5 speed, custom interior, 14 tv\'s, ps2, , custom stereo, hood, bruiser front, sides, roll pan, custom exhaust,20 inch rims, air ride system, 4 12inch subs in a molded in a box, member of del val and GROUNDED 4 LIFE. vertical doors, big ass ragtop roof, 10.5 inch screen in steering wheel, move window switches to glove box, glassed a tv where the switches were, smoothed dash and painted, led tailights, tv;s in quater panel windows
FRESH TWO TONE GREEN AND SILVER , SHAVED TAILIGHTS WITH LEDS IN THE ROLL PAN...
Old 20 Feb 2004, 03:34 pm
The idea is to pick up the 12V off the fuse block inside the car, rather than going thru the firewall to get at the battery.
Old 20 Feb 2004, 04:12 pm
oh, if they're interior neons....ok I see....tap the wire into the same fuse that runs your radio, that's usually a good one.
Old 20 Feb 2004, 05:49 pm
i tried to use my circut tester and i can't get the signal from the fuse block when i use the ground infront of the car in the engine compartment by the hood latch. There are fuses for heated seats that i don't have. Is there a way to use them, and use a fuse tap. I tested them but it didnt light up the tester.
Cruiser Dan
<font color=\"blue\">Patriot Blue</font id=\"blue\"> 02 5-Spd
Old 21 Feb 2004, 02:33 pm
Any one know why i cant get a circut tester to light when i connect to my heated seats fuse block. I was grounding at the hood latch in the front. Where its a recomended ground for a jump start.
Cruiser Dan
Old 21 Feb 2004, 06:34 pm
Hope somebody smarter than I am replies so I can learn something! Did you try your light across the battery and make sure it's okay? [:I]
Closed Thread
How to get power to my mp3 player & other concerns Doktor X Sound and Security Forum 3 29 Jul 2005 10:38 pm
POWER WINDOW MOD WAYNEF Interior Accessories Forum 13 13 Jan 2005 05:40 pm
Crappy Ground Wire Mean Green General Turbo Discussions 2 31 Dec 2004 09:56 pm
New reason to love my pt! technobear General PT Cruiser Discussions 9 03 Aug 2004 07:16 pm
Need help with signal mirrors KingKole02 Exterior Accessories Forum 16 23 Jan 2004 05:09 pm
