Do lights/lighter drain battery to death?
Closed Thread
  #11 (permalink)
Old 04 Mar 2004, 01:34 am
the lights turn themselves off if you leave a door open. However, if you turn a light on manually, it will stay on. that is surprising to me. my 96 dodge caravan turns off the interior lights after 10 minutes even if you have manually turned them on. if the PCM detects current flow to the lights, it will turn them off after 10 minutes. opening a door or turning the light of and then back on resets the timer. the van also turns off the headlights after 5 minutes if you leave them on. don't know why the PT doesn't have these features. If you are concerned about the battery going dead, buy one of those jump start packs. the cheap ($39-49) one is all you need. i have that and have used it to start everything from motorcycles to 5.0 V8s and diesel construction equiptment. it is worth it's weight in gold. havent had to use it o the PT yet. knock on wood.
2003 turbo dreamcruiser
  #12 (permalink)
Old 04 Mar 2004, 08:11 am
Because the wiring diagrams in the service manual show the manually switched lighting power goes directly to B+ battery, instead of through the BCM.
I prefer it. If I need interior lighting for a night time event, I don't want the lights turned off by the body control module.
Closed Thread
PT Crusier battery dies after 5 days of no use. PT OWNER General Turbo Discussions 22 28 Jan 2009 11:51 am
Battery change turbomangt General Turbo Discussions 18 24 Jun 2008 02:58 pm
Check & drain you water heaters, A/C , &.... Espresso Non-PT Discussions 17 12 Jul 2005 11:47 am
Battery Corrosion SteelBlueGT General Turbo Discussions 9 19 May 2005 06:47 pm
Drain plug DREAM2 General Turbo Discussions 11 06 Jul 2004 10:14 am
