tie rod ends
Closed Thread
Old 04 Mar 2004, 02:14 am
Default tie rod ends
Has anyone out there been told that their tie rod ends have to be replaced instead of lubricated with a zurg fitting?
Old 04 Mar 2004, 03:18 am
From the Service Manual:
Worn Or Loose Tie Rod Or Ball Joint
Tighten Or Replace Tie Rod End Or Ball Joint
2002 Inferno Red PT Limited
Mercedes Wiki
Old 04 Mar 2004, 09:15 am
There aren't any Zerk fittings on there, are there? The infamous "lubricated for life", only the life is too short!
Old 04 Mar 2004, 09:24 am
If there were they would have removed them. Here's what the service manual has to say about the ball joints.
STANDARD PROCEDURE - LUBRICATION
There are no serviceable lubrication points on the
front suspension. The front lower ball joints have
grease fittings which have had the head snapped off
by the manufacturer after they have been filled.
This
has been done to eliminate the possibility of damaging
the non-vented seals. Grease will not leak from
the broken grease fittings. The ball joints are sealed
for life and require no maintenance.
CAUTION: No attempt should be made to replace
the ball joint grease fitting with a new fitting, then
filling the ball joint with grease. Damage to the
grease seal can result.
Mercedes Wiki
Old 04 Mar 2004, 09:55 am
My last 6 vehicles have been this way[:I]
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 04 Mar 2004, 10:43 am
I bet you they do this because 90% of the boneheads at places like Jiffy Loose always put *way* too much grease in them and bust the seals on the ball joints.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 05 Mar 2004, 12:33 am
roger that 3jack--not just any of the fast lube places either. blowing out the lube point seals is a great way for less than honest places to have you come back later for the replacement of the "well lubed" parts.
03 GT
Closed Thread
Xenon Crusher front ends WampsPT Exterior Accessories Forum 1 24 Mar 2006 12:03 am
XENON front ends? 1lowufo Exterior Accessories Forum 3 09 Jan 2005 11:09 am
Painting odds and ends SwtNLwPT General PT Cruiser Discussions 2 02 Apr 2004 10:02 am
Chrome beltline kit......how to touch up cut ends? CraigO Exterior & Interior Styling 5 17 Jul 2003 02:45 am
