Says runs Hot
Closed Thread
Old 31 Mar 2004, 09:36 pm
Default Says runs Hot
He everybody. This is a simi tech question. my temp for water runs 1/2 between H&C which seems high to me. I do run the air. Is that normal what are normal readings?
Old 31 Mar 2004, 10:03 pm
Now driving my second Cruiser and the needle always sets right in the center between h & c after it warms up. Must be ok.[8D]
Old 31 Mar 2004, 10:21 pm
If the guage reads halfway between Hot and Cold, then it would be neither Hot nor Cold........hence, safe to assume normal.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 01 Apr 2004, 12:13 am
I have to agree mine stays right in the middle.
Greg Gavencky
The New Jersey Cruisers
www.njcruisers.com
Old 01 Apr 2004, 03:20 am
Several automotive manufacturers have found through painful experience that if they put "real" gauges on their vehicles the dealers get more customers coming in complaining about problems with higher temperatures or lower oil pressure, etc when there is a slight change. To avoid this situation, the manufacturers did the more knowledgeable drivers a great disservice. They made a gauge that is little more than a warning light. The temperature gauge on the PT Cruiser, like the oil pressure gauge on Ford trucks and vans, is designed to register near the center of the gauge range without movement even though the actual readings are changing. Only when the readings are very low or very high does the gauge move.
That is why you will see many performance oriented PT owners adding an aftermarket temperature gauge that will actually tell them what is happening rather than waiting until thing get more extreme before the gauge moves.
Unfortunately, most of the driving public really only wants to know if they are in trouble right now, so idiot lights and semi-functional gauges/highly damped are the rule of the day.[xx(]
Old 01 Apr 2004, 05:18 am
Thanks Micheal. That makes a lot of sense, I guss this leads to another question if you don't mind answering. Or anyone. These are such small engines what besides geting a after market temp gauge, to keep an eye on things, will improve the cool runing of the car. It seems the little four banger would tend to want to overheat. I don't know enough about the engine. The car is 2002 and 3 month new to me. I was attracted by the looks design and praticaity of the car but don't know how the engine will hold up. Any suggestion would be appericated.
Mahalo, Rod
Old 01 Apr 2004, 08:28 am
Rod, If your worried about the temp You could try Redline Waterwetter, I put it in my Dodge Ram and the running temp dropped about 8* although its not made to just drop the temp, it dose.
My PT runs just a hair below the center line also, It's just where they run, I've switched to Mobil-1 synthetic oil to reduce friction and will pick a bottle of water wetter up soon. Also you might consider a high flow catalitic converter as the more restricted holds a lot of engine heat.
03 Electric Blue Touring PT
Old 01 Apr 2004, 09:48 am
Same here. Year around.[|)]
Old 01 Apr 2004, 11:25 am
Get a 180 Degree Thermostat.
www.cybermopar.com
TripleJack
Closed Thread
I got the runs.... crazie.eddie Tech & Performance Forum 7 19 Oct 2004 03:59 pm
July 2nd Englishtown Runs Beacon General Turbo Discussions 11 23 Jul 2004 03:07 pm
Gtech runs for my turbo lite nuke72 General Turbo Discussions 3 02 Jun 2004 09:23 pm
nothing runs like a deer VellianPT Non-PT Discussions 2 23 May 2004 04:04 pm
Adam's Intake & Upper Charge Pipe - Dyno'd! Mike-in-Orange Vendors & Buyers Forum 39 29 Mar 2004 12:29 am
