APC tails condensation problem fixed
Closed Thread
Old 01 Apr 2004, 11:29 am
Default APC tails condensation problem fixed
I had problems with condensation in my APC gen II tailights. Called APC no help said I should return to place I purchaced from.[xx(] Well to make a long story short after getting the run around I decided to fix them my self. After removing the offending tailight I drilled a 1/8 hole in the backside of the light near the top. Also on the side under the reflector so it will not be seen. I reinstalled the light and checked to see if you can see the hole I can`t. Well the light has been on for about three weeks now and the condensation has cleared up and not returned.[?]
Old 01 Apr 2004, 11:43 am
Coop,
I've since sold the lights, but I did the same thing about a year ago. APC did send me a replacement set of lights and said they had fixed the problems (melting lenses, condesation) but I took no chances and put extra holes (2 in the back of each bulb) and had no problems after that.
Old 01 Apr 2004, 02:05 pm
Cruzin is right vent holes should work. If you looked at the back of the new aftermarket back up light assy, (YBC I think) you will find a vent nipple with a small piece of vacum line on it. Thats how they keep them from fogging up.......
Old 01 Apr 2004, 02:49 pm
I have the same broblem with one of my factory tail lamps... I talked to the regional manager... No waranty repair for condensation!!!
I guess I will do this fix myself and get it over.
Old 01 Apr 2004, 04:03 pm
Ian,
Here's what I did. I took a drinking straw and cut a few pieces along the length of the straw about half inch in length. I then drilled holes in the back of the taillights the same diamiter as the straw. I glued the small pieces of straw into the holes so air could get in and out but water would have a hard time getting in, in case water happen to spash up inside the fender. I put two of these hole/straws in the area around each bulb.
Old 01 Apr 2004, 08:33 pm
Sounds like some good "fixes" !!
Closed Thread
Fixed timing belt now another problem EvilWRX Tech & Performance Forum 1 13 Feb 2007 09:35 am
anybody fixed this problem? 4SPEED Tech & Performance Forum 9 25 Oct 2006 07:55 pm
mysterious rear knocking noise was found FIXED!!:) Ctown General PT Cruiser Discussions 3 01 May 2006 12:40 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
Bumper problem fixed stirfry General PT Cruiser Discussions 18 24 May 2004 04:02 pm
