What is the advantage to putting new springs into the pt? sorry i don't hold an enginering degree nor am i mechanicly inclined (if anyone is a george carlin fan, will recognize the quote). I'm just a lowly flight medic.
Tac Evac Bring \'em Back |
Good question, the reason I'm doing the rear is to even the rake of the car, and hope to improve handling, my lowering the center of gravity.
2003 Turbo GT 5-speed/ www.perfectautofinish.com Founder/ Chicagoland PT Cruiser Club Contributing Editor, PTCruiserLinks.com www.ptcruiserlinks.com/garys-cleaning-tips |
GstnNole, welcome to the forum!
![]() 2002 Inferno Red PT Limited Photos and more at: http://www.randgraphics.org/PT_Cruiser/demos/index.htm Mercedes Wiki |
Gary , I used Dons method and it worked.It was a snap.
Put a 2x6 under rear axle jack up car take off rear wheels put jack stands under side jack points high enough to get springs out(about 3 notches on my stands)remove the 18mm bolt from bottom of shocks.Lower floor jack remove springs put in new ones. Raise rear axle high enough to put bolts back in shocks.put on wheels.Raise car to remove jack stands. lower and you are done.I had to drive car up on 2x6's to get floor jack with 2x6 under axle.
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
Gary I think that you ought to go with the springs all-around and watch where and how you drive. I've seen the rear only and the PT does not seem to sit right.All-around and a BTG Turbo strut bar add alot to the handling. |
| Cutting Springs...... | Wicked_PT | Wheels, Tires, Suspension | 6 | 19 Dec 2005 11:45 am |
| Lowering springs installed. | Espresso | Wheels, Tires, Suspension | 2 | 10 Jun 2005 11:27 am |
| Otto Racing Springs | matt87951 | Wheels, Tires, Suspension | 7 | 06 Apr 2005 04:23 pm |
| Lowering Springs, part II | eliminator | Turbo Wheels/Suspension/Handling | 3 | 03 Feb 2005 11:50 pm |
| Progress Springs | cruisrman | Wheels, Tires, Suspension | 10 | 22 Apr 2004 08:36 pm |
