| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
hey new here....
so i hit a deer with my 01 pt and it was pretty bad (they almost totaled it) and i got it back from the body shop and i have/had a few problems with it 1 (fixed) power steering was making noise... fluid was low 2 headlights seem to be pointing down this is got me stumped .... do i have to take to a dealer or can i fix it myself? if so how? |
Welcome, Bobbiac.
I just had a deer encounter, too, only mine was driver's side. Anyway, abouth the headlights: http://www.ptcruiserlinks.com/forum/...light,adju st hope that helps.
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
Welcome to the Forum bobbiac [^], good place to get info!!!
Welcome to the forum bobbiac!
![]() 2002 Inferno Red PT Limited Photos and more at: http://www.randgraphics.org/PT_Cruiser/demos/index.htm Mercedes Wiki |
Welcome!
Sorry to hear about the deer. Good Luck getting back up to speed.
\'03 PT Turbo 2CN Auto/Stick Lt. Almond/cloth Blanes HoodStruts etc. |
Sorry to hear about the evolved road rat incedent. Aligning headlights is easy for my 03. All I did was get a torx 20 star screwdriver for 2 dollars at an auto parts store. My alignment screws are located in the first hole under the turnsignals. Headlamp Unit Standard Procedure - Headlamp Unit Alignment Alignment Screen Preparation 1. Position vehicle on a level surface perpendicular to a flat wall 7.62 meters (25 ft.) away from front of headlamp lens. 2. If necessary, tape a line on the floor 7.62 meters (25 ft.) away from and parallel to the wall. 3. From the floor up 65.8 Centimeters (26 in.), tape a vertical line on the wall at the centerline of the vehicle. Sight along the centerline of the vehicle (from rear of vehicle forward) to verify accuracy of the line placement. 4. Rock vehicle side-to-side three times to allow suspension to stabilize. 5. Jounce front suspension three times by pushing downward on front bumper and releasing. 6. A small dot is molded into each headlamp lens signifying the center of the low-beam headlamp. Measure the distance from the center of the headlamp to the floor. Transfer measurement to the alignment screen (with tape). Use this line for up/down adjustment reference. Headlamp Unit Alignment The headlamp low beam pattern has a distinct horizontal cutoff line, which is used to visually align the headlamps. A properly aimed headlamp will have the top of the horizontal cut off line of the low beam pattern aligned with the horizontal line on the wall. The high beams on a vehicle with aero headlamps cannot be aligned. The high beam pattern should be correct when the low beams are aligned properly. To adjust headlamp unit alignment, rotate alignment screw to achieve the specified low beam hot spot pattern. (Look for the recessed area under the headlamp to locate the Torx head alignment screw.)
KingKole02 ![]() SW Florida PT Cruisers Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics For cruiser pics go to: http://ptcw.truckmoxie.com/mygallery.ten?id=3464 http://smg.photobucket.com/albums/v8...0in%20my%20PT/ For my personal page, visit http://www.kingkole02.com http://random-input.blogspot.com http://www.ptcruiserweekly.com www.jumpsometravel.com Travel Everywhere! - Owner |
| I cant get an alignment with 20's goldline springs | ptcruz311 | Wheels, Tires, Suspension | 6 | 02 Aug 2006 05:28 pm |
| wheel alignment | onyx pt | Turbo Wheels/Suspension/Handling | 2 | 19 Aug 2005 09:10 pm |
| camber alignment kit needed for front ??? | boosta | Turbo Wheels/Suspension/Handling | 7 | 10 Jun 2004 11:25 am |
| ..headlight bulbs and adjustment.. | earringboy | Tech & Performance Forum | 17 | 30 Dec 2003 05:14 pm |
| Alignment Kits | jramosGT | Tech & Performance Forum | 6 | 14 Jan 2003 12:47 pm |
