Nut size for the negative battery ternimal cable.
Closed Thread
Old 14 Apr 2004, 04:46 pm
Default Nut size for the negative battery ternimal cable.
What size is the nut on the negative cable wire. Mine is stritped and I can hardly remove it and need a new one. I check with an auto parts store and the one I bought was too big.
Any help
Thanks.
Old 14 Apr 2004, 08:38 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
King,
Checked my books and cd but no info on the size of the bolt but you use a 10MM wrench to loosen the neg terminal. Hope this helps
Gonz
Old 14 Apr 2004, 08:59 pm
quote:Originally posted by gonzomania
King,
Yup, it's a 10mm........cuz I was pissed when I couldn't find my 10mm last time!
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 15 Apr 2004, 08:53 am
10mm, huh. I will have to see what I can get at a parts store. The first time they sold me something too big. The jerk said it was universal. I guess I can't blame him for wanting to wait on the hot girl behind me as soon as he could.
Kingkole02
Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics
Old 15 Apr 2004, 09:35 am
If you buy the nut AND the bolt, it's guaranteed to be the right size...
Old 15 Apr 2004, 10:29 am
Don,
Thanks what I bought and it still didn't work the nut was way to big.
Kingkole02
Old 15 Apr 2004, 07:43 pm
How about using a couple of flat washers to lift the nut away form the bolt?? [:I] Is the nut OD to large to turn? Another suggestion take the orginal bolt in and try the nut to fit.
Old 16 Apr 2004, 02:23 pm
Hooligan,
The nut is larger then the original bolt. I would have to replace the whole nut and bold. Im not sure if the bold will fit the hole through the cable hookup piece.
Kingkole02
Old 17 Apr 2004, 03:09 am
2sb 2sb is offline
Sounds like what you got is the standard replacement bolt/nut in SAE for the old lead-type battery cable ends. Take your metric bolt in with you to get a nut and maybe a flat washer to give you more clearance.
Old 20 Apr 2004, 03:23 pm
Any help
Thanks.
I suggest you buy a pair of replacement clamp-on cable end terminals (+ and -), and cut off and replace the cheesy stamped steel pieces of cheap-a$$ crap D-C supplied.
Installation takes a few minutes, and future problems caused by bad battery connections will be avoided.
Closed Thread
Disconnecting battery cable TaylorMade Tech & Performance Forum 6 08 Aug 2004 11:24 am
Negative battery terminal disconnect necessary? KingKole02 Sound and Security Forum 11 16 Feb 2004 03:12 pm
