Leaky rear window washer
Closed Thread
Old 02 May 2004, 09:26 am
Default Leaky rear window washer
My wife's seems to have a leaky rear window washer.I thought
maybe see was hitting it by mistake,but she says she isn't.
I clean the rear window and the next day you can see where
a little stream of water has come out of the washer and a dirt line is running down the back window .Anybody else have this problem?
Old 02 May 2004, 09:31 am
Jimbo,
There was an issue with some '01 and '02 PTs that had weeping washer nozzles. If I remember right, some cars were having the rear washer nozzle weep. If you have less than 36,000 miles, it's a warranty item. Take it in...
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 02 May 2004, 09:33 am
That is a problem thet chrysler has a fix for. I don't have the TSB, but my understanding is that chrysler can put in a plastic check valve in the fluid line just before the spray nozzle to eliminate that leaking. I think that there is a TSB about this issue...
Closed Thread
Oval Rear Window judpma Exterior Accessories Forum 4 19 Jul 2005 09:19 am
Broken rear quarter window! littledog General PT Cruiser Discussions 12 20 Jan 2005 09:20 pm
R&R the rear window glass? Cal Cruzer General PT Cruiser Discussions 3 18 Nov 2004 12:26 am
Rear window washer PTSleeper General PT Cruiser Discussions 12 12 Nov 2004 07:55 pm
Split Rear Window Kit sctvguy Exterior Accessories Forum 3 23 Oct 2003 01:01 pm
