shiftknob
Closed Thread
Old 15 May 2004, 10:06 am
Default shiftknob
i have a 02 pt touring 5-speed and im trying to get my shiftknob off but its not coming off its like they welded it on or something..anyone else have this problem? how can i get it off?
Old 15 May 2004, 10:49 am
My autostick has an allen screw holding it on does yours? Not familiar with the manual shift knob though. Some one will give you the answer shortly.
RD CHILI -- PHUN Time Cruisers Club
04 GT Inferno Red Loaded, Mopar Dual Exhaust, K&N Air Filter, Mopar Cabin Air Filter, Mopar BOV Kit, Blane Hood Struts, Strut Tower Brace, Kaiser Custom 17\" Wheels, Nankang Sport NS-1 225/45R17 Tires, Custom Decals, TYC Back-up Lights, LED Glow Lights in and out, Red Fuzzy Dice, Yet To Go; Mopar Stage-2 Turbo Kit, Mopar Stage-2 Suspension, Custom Paint.
Old 15 May 2004, 12:05 pm
Stock five speed shift ball is glued on. Wrap the ball in a towel and use a hammer to tap the ball loose from the underside. It comes off with a little tap.
Homepage:
Old 15 May 2004, 12:36 pm
thanks i will try that[^]
Old 15 May 2004, 01:28 pm
Or - wrap large-jaw pliers in a rag, close loosely below ball, smack up on pliers with hammer.
Old 15 May 2004, 03:21 pm
You should be warned that the 2002 5-speed shift ball will come off towards the front windshield and dash, so be careful. There's a notch on the front part of the shifter shaft and the shifter ball has a corresponding bulge inside that locks the ball in there. As noted by others, place a towel under the shifter ball and around the shaft (to prevent any marring or scratches), use a crescent wrench or a big pair of pliers under that and gently hit the crescent wrench/pliers with a hammer to loosen/remove the shifter ball.
Many 5-speed owners change the OEM shifter to a Hurst or B&M short shifter so they can use whatever shifter ball they desire since the replacement shifter has a standard 3/8"-16 UNC thread. Also they replace the OEM shifter bushings to the solid Booger Bushings to get a more positive shift and remove the rubbery feel.
Old 15 May 2004, 03:24 pm
thanks ..i just love this site everybody is sooo helpful
Closed Thread
Automatic Shiftknob Conversion? DevilMan Interior Accessories Forum 10 07 Apr 2006 08:51 am
