Bulletin on the spark plugs check it out
Closed Thread
Old 18 May 2004, 11:54 pm
Default Bulletin on the spark plugs check it out
there is a bulletin out on the spark plugs for the 2003-2004 PT's with the 2.4L engine,with the plugs RE14MCC5 they are no good and the dealer has to replace them with the new ones it is a running change if you bought before March 2004 they need to replace them with 05149002AA (9RE16MC)OR 01549003AA (LZTR4A_11) with the new plug gap 1.016 mm I just got a copy of the flyer today after I had a prob with my PT again on mond they kept it over night and replaced them this morning I drive 2.3 miles and my car miss fires and tries to stall out...so once again I am in a rental...and they have the corperate tech coming this week to check it out...LEMON LAW...trading it in for a new and runable PT...so if you had these probs ask them to check into this bulletin #08-008-04 Electrical [8)]
Old 19 May 2004, 08:20 am
Thanks for posting. Been seeing lotsa folks with new PTs with plug problems. Are they still Champions? Anyone know how the problem arose? And gap in MM, not inches? [:I]
Old 19 May 2004, 08:59 am
[:I]What about those of us that payed to have our plugs replaced - any comment on that
Old 19 May 2004, 10:19 am
I believe that 1.016mm comes out to be in the neighborhood of 0.0395 to 0.040
There will be someone here who will know exactly. Either way, it appears to be alot lower then the original of 0.050
Old 19 May 2004, 11:43 am
Damn I just changed mine last night to .45. Went with the Champion Double Platinums, and 8.5mm Magnecor wires. Maybe I shoud've gapped them at .40 instead.
It seems to run better though.
Kingkole02
Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics
Old 19 May 2004, 11:47 am
How can you check for the bulletin?
Kingkole02
Old 19 May 2004, 01:01 pm
ask your dealer service department to look at there bulletin they get for recalls...ect they will know which ones...as of the ppl that payed I would go to the dealer and demand a refund it is their faults...Id call asap...[?]
2004 Seamist Green PT.. my beautiful Lemon
Old 19 May 2004, 02:46 pm
Well what I got and used they wouldn't have told me to get. I want to know if I should re gap my plugs or not.
Kingkole02
Old 19 May 2004, 03:43 pm
King, do you have any issues with the way the GT runs @ .045 gap ?
Mine are gapped @ .042 and runs real strong. If you're happy and sure that the GT is running good, I'd run it for a while. If you're unsatisfied, re gap the plugs. Even @ .042 (like mine) it is still .002 wide, but I'm not changin it cause it runs well. Judging the way your car runs is alot like judging how your stereo sounds. No matter what the specs of the equipment that you use, you need to trust your ears as to how it sounds. Many factors are involved. The same goes with judging how your GT runs. No matter what the gap spec is, if it runs good @ .045 there is no need to change it. I closed mine to .042 because @ 15lbs second stage boost (higher boost at lower RPM too)the spark was intermittently being blown out. Narrowing the gap .003 to .042 remedied any issues w/high boost.
Old 19 May 2004, 04:07 pm
Gear Head if I was running a GT I probably would have already done this. Im sorry but mine is a N/A. I originally was told that .45 was good for the N/A engine but really was tested yet.
What did it do when the spark would blow out?
Kingkole02
Closed Thread
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
E3 Spark Plugs CREWZIN Tech & Performance Forum 6 11 Dec 2004 01:03 pm
Spark plugs: newbie question Edwin Astacio Tech & Performance Forum 12 01 Nov 2004 12:21 pm
ZEX Spark Plugs Jerry Tech & Performance Forum 9 27 May 2004 07:32 pm
Ignition Questions....need help. spark plugs ptcruzin42 Tech & Performance Forum 5 15 Mar 2004 08:39 pm
