Check Engine Light
Closed Thread
Old 22 Jun 2004, 05:11 pm
Default Check Engine Light
I was driving home from work today, and after only a mile or so, the check engine light came on (light that looks like an engine block). There seemed to be nothing wrong with the car, sounded fine, shifted fine, smelled fine, no smoke, nothing. Anyone gone through this sort of situation before? Is it something simple or could it be that there is a serious problem down below deep within the engine?
Old 22 Jun 2004, 06:48 pm
Send a message via AIM to Konkeler
Did you make sure to turn the gas cap so it clicked twice last time you filled it up?
Here is picture of My Cruiser\'s Mirror
Old 22 Jun 2004, 06:49 pm
You might want to check if your gas cap is on tight. In addition, I think for Chrysler cars, it takes about 40 "cycles" (can't remember the term) of normal operations for the CEL to go away OR you can disconnect the battery to get rid of the CEL if it relates to the gas cap.
Old 22 Jun 2004, 07:40 pm
I had been driving on the same tank of gas for about 160 miles when it came on. Already took it to the dealer, so we'll see what they say.
Old 23 Jun 2004, 08:24 am
Please let us know what dealer finds. [:I]
Old 23 Jun 2004, 10:37 am
Mine did the same exact thing. I found the code the computer was spitting out, turns out that I had a bad spark plug and needed to change them. It took 3-4 drives and then CEL went out after changing the plugs. Hope it's nothing serious.
[8D]
Old 23 Jun 2004, 04:58 pm
Turns out that it was the gascap. It took the sensor 160 miles to figure it out though. No major problem, and Chrysler didn't charge me a cent.
Closed Thread
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 15 23 Jul 2010 06:09 am
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 11 16 Jul 2008 11:46 pm
Faulty Check engine light? Mel K General Turbo Discussions 5 23 Mar 2007 10:06 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
Clearing check engine light Blade Tech & Performance Forum 10 27 Mar 2004 01:48 am
