PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Windscreen Washer
Old 13 Apr 2007, 04:16 am
deanc deanc is offline
Default Windscreen Washer
I don't know if anyone else has had this problem, but I am experiencing very poor strength from the water jets to clean front and rear windows. Nothing at all coming out of rear one. I can hear the motor running but not much water comes out.
Any help/advice appreciated.
Many Thanks
Old 13 Apr 2007, 06:53 am
Johns Steel Blue's Avatar
Johns Steel Blue Johns Steel Blue is offline
Default Re: Windscreen Washer
Many Thanks
More than likely they just may be blocked from sediment/calcium if you put in water. I'd remove the plastic tube leading to the jet under the hood and then try and see if it flows. If it does, the sprayer itself is probably blocked up. I would think you could remove then and clear them with something like CLR or Limeaway.
John
"The problem with the designated driver program, it's not a desirable job, but if you ever get sucked into doing it, have fun with it. At the end of the night, drop them off at the wrong house."
Old 13 Apr 2007, 07:52 am
i2s2bme's Avatar
i2s2bme i2s2bme is offline
you would be surprised how many people never check the levels and assume it is taken care of when the car is serviced. and the back uasually has a seperate resovior aswell
Old 13 Apr 2007, 09:04 am
hharper1321's Avatar
hharper1321 hharper1321 is offline
Nope, the back doesn't have a seperate reservoir. But, check your levels. You may also have a broken sprayer. they tend to break right at the 90 where the hose hooks up. I've gone through more than I can keep count. The constant heat/cool cycle makes the plastic brittle..... I have a fix in mind, but, as I haven't tried it yet, I won't offer it....
2004 PTGT - Stage 1 and a bunch of bolt-ons, even more bolt-ons waiting in the garage!
How come "The People" in the First Amendment means The People; "the People" in the Fourth Amendment means The People; but "the People" in the Second Amendment (ratified in 1791) means the National Guard (created by an Act of Congress in 1903)?
Old 14 Apr 2007, 07:18 am
I had already checked the water level, the resevoir is full.
I have unattached at the T-piece and tried the wipers, very little coming out.
My gut feeling is it is blocked somewhere between the resevoir and the T-piece.
What's the best way to unblock?
I can hear the pump running, does that mean it is necessarily working?
Old 14 Apr 2007, 04:32 pm
Hooligan Hooligan is offline
Air Compressor, blowback lightly!!!!!
2006 Black Limited, NA, Sirius; chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty cover; Champion 7570 Platnium Plugs (.040); MOPAR Performance Wires; 2005 Chrome GT MOPAR wheels; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot rest Pedals, Chrome side spears.
vB code is On
Rear window washer PTSleeper General PT Cruiser Discussions 12 12 Nov 2004 07:55 pm
Pressure washer Mr.Barton The Detail Shop 7 27 Oct 2004 09:19 pm
Washer Nozzles SRG General PT Cruiser Discussions 2 02 May 2004 11:25 am
relocate windshield washer rnbenoit Exterior Accessories Forum 6 03 Aug 2003 11:22 pm
LED Windshield Washer Lights Jerry Exterior Accessories Forum 2 29 Sep 2002 01:59 pm
  Power Rangers | Lebanese | Online Loans | Credit Card Debt | Bedroom furniture spaces
