Convertible passenger side windows don't go down
Old 08 May 2007, 08:18 pm
Default Convertible passenger side windows don't go down
I have a a 05 PT cruiser convertible. Both passenger side windows do not go down. there is no movement at all not even the little down when you open the door.
I have checked all the fuses none indicate passenger side only and none are blown. I have replace the switch no joy.
Here is a little history it was miss firing and the service engine light was on. Before I drove to my fathers house (he had the engine scanner) I disconnected the battery (positive terminal) just to see if clearing the computer would fix the problem. again no joy (it was worth a shot (maybe))
The engine code showed miss firing on cylinder 3 switch plugs 2 and 3 the problem moved so I replaced the plug. What does this have to do with the windows not working maybe nothing but immediatly after changing the plugs the windows stopped working and I don't really believe in coinsidence. I was wondering if maybe I reset something disconnecting the battery. I can't say for sure that the windows worked between changing the plugs and disconnecting the battery.
Any ideas would be appreciated
Thanks
Old 11 May 2007, 01:47 pm
Default Re: Convertible passenger side windows don't go down
Welcome.
1) You have warranty left? If so, take it to dealer.
2) Buy a mutimeter and check if you have 12V at the window switch. If so, then you may have to take door panel off and check voltage to motor.
3) My bet is that your misfire will return unless you replace the wires, too - it's usually the wires that go bad. Get better wires and they'll last longer.
4) I'm guessing that somehow a ground on passenger side got loose.
It could be worse - windows could be down and you couldn't get them up!
Old 11 May 2007, 02:18 pm
take it back to the dealership !!
Old 13 May 2007, 12:27 pm
Thanks for the replies.
1 Unfortunatly I have no warrenty left.
2 I did check the voltage at the switch and it was good.
3 I thought about the wires and will do that but need to order them and wanted to get it going. and the plugs fixed it (for now)
Actually my stupidity last week fixed the problem. I left the lights on killed the battery and after boosting it TA DA they worked again.
So I now have aperfectly good used power window switch for sale if any one wants it
Thanks again for the replies
Old 14 May 2007, 12:39 pm
While I'm glad your windows are working, I'm puzzled by what the cause was....
Another place to look - if it ever comes back - the windows need the key on to wrok, right? I'll bet there's 2 wires that goes thru key switch - one for driver side, one for passenger side...
Passenger side airbag pt-banjeral Tech & Performance Forum 6 13 Jan 2006 09:36 am
wtb passenger side armrest josheypt Interior Accessories Forum 0 06 Nov 2005 03:30 pm
2005 PT Cruiser Convertible Pricing and Specs skylight PT Cruiser News and Rumors 16 20 Mar 2004 11:13 am
Whisling passenger side door/window.. amazingarthur General PT Cruiser Discussions 7 20 Jan 2004 02:02 am
question on wind noise from side windows comPuTer General PT Cruiser Discussions 14 03 Sep 2003 09:12 am
