Replace Multifunction Switch w/fog lamps
Like Tree24Likes
  #161 (permalink)
Old 24 Jun 2016, 11:35 am
Fk5 Fk5 is offline
Default Re: Replace Multifunction Switch w/fog lamps
Originally Posted by 044400 View Post
LOL, ""What did HE do that for?"
Ha.
I hope I put them back on (the clips ) but I honestly can't remember.
2003 GT 5 speed
162,000 miles
  #162 (permalink)
Old 30 Jun 2016, 08:20 am
amarine1's Avatar
I went to the junk yard yesterday, and pulled a Multi-function switch from the only PT Cruiser in the yard with fog lights (a 2001 PT Cruiser Limited). The part number shows as a different number, but they matched identically otherwise. For $20 cash (and a hour and a half in the yard hunting/removing), it was in great shape so I took a chance it would resolve my Multi-switch issue.
I installed it when I got home, and woooola - a functioning set of lights (low and high beam), turn signals, emergency lights, and WOHOO....... fog lights with the fog light indicator lighting up on the cluster also. Problem RESOLVED.
dougs and donn like this.
2008 Chrysler Sebring Touring (metallic silver) H/T, 88,000 miles (2nd owner).
2005 Chrysler PT Cruiser Touring Convertible (Off White) 107,300 miles (2nd owner - 2.4 Turbo engine).
2009 Toyota Sienna Mobility Minivan, 28,500 miles (2nd owner ).
E-4 USMC 1981-1988 - Motor T - Honorable
  #163 (permalink)
Old 22 Oct 2017, 12:59 pm
2006 PT Cruiser Left hand (turn signals and lights) Multi-switch replacement. I thought I would pipe in here because I just changed my 2006 multi-switch. I started to follow KC's instructions and realized that those instructions must be for a different year model. Actually, the 2006 is much easier to change. It is best to have the column all the way up and the seat all the way back. There are the two Philips head screws on the bottom like KC describes, but there is also a third screw on the bottom in the middle. It is a torx, not sure what number, but pretty small. No screws on the top required to get the covers off. No need to mess around with the right side multi-switch or the ignition switch. The left side multi-switch is held in by a single Philips head screw that enters from the left and is parallel to the ground. Remove that screw and then slide the switch out far enough to clear the plastic guide on the column and then position it to remove the small harness from the back and the larger one from the right. Unit is clear and it only remains to install the new one by the reverse process. There is no little red tab to deal with on the 2006.
  #164 (permalink)
Old 22 Oct 2017, 03:06 pm
rckstein's Avatar
Thanks for the info
This is the MFS, where I have placed the arrow is that where the single screw is that you said holds in the switch?
'06 Touring Edition NA Automatic
163k Miles / Electric Blue Pearl
USMC '82 - '93
  #165 (permalink)
Old 09 Nov 2017, 02:25 pm
YES. That's it.
rckstein likes this.
  #166 (permalink)
Old 16 Dec 2017, 03:55 pm
I finally got my wiper switch off of the 2006 PT Cruiser. Already had the handle with the broken ribbon cable. Now the two parts are in my hand.
A Sticker on this right side of the steering wheel switch says 212842323
When I search on parts houses it wants to know my engine model
8 2.4L MFI Turbo DOHC
B 2.4L MFI DOHC
E 2.4L MFI Turbo DOHC
G 2.4L MFI Turbo DOHC
S 2.4 MFI Turbo DOHC
X 2.4L FI DOHC
I looked under hood, but couldn't see a sticker with those numbers.
And when I go to auto parts there are 4 or 5 choices depending on engine.
Its a 4 door Hardtop
Where do I look for engine model?
  #167 (permalink)
Old 16 Dec 2017, 04:58 pm
Went by the dealer with the VIN
Printout says Engine is a EDZ-2.4L 4 Cal DOHC 1V SMPI Engine.
So what choice is that above.
And the part # for that wiper switch is 68003215AD, and from reading a listing online, that part could be in a lot of post 2006 Cruisers, Jeeps, and other Chrysler products.
Junk yard, should be possible, if I am lucky
  #168 (permalink)
Old 16 Dec 2017, 05:19 pm
VsandFords's Avatar
I think the eighth digit in the VIN is for the engine.
Multifunction switch gonzomania General PT Cruiser Discussions 20 07 Apr 2015 07:08 pm
MultiFunction Switch Issues-HELP !!! jmack General PT Cruiser Discussions 10 26 Mar 2012 01:58 am
Multifunction switch for postage Shini Quiet Classifieds: For Sale/Trade 0 23 Sep 2004 10:29 am
Multifunction switch gonzomania General PT Cruiser Discussions 5 23 Feb 2004 05:35 pm
